Home > Puma (Tdci) > Broken spline in axle housing
Page 1 of 3 123>
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Morning all
I overhauled the swivel and hub over the weekend . On removing the swivel I found this little bit of metallic debris sitting just inside the housing . It clearly looks like a tooth from one of the components but is approximately 3-4 times the size of a half shaft spline . Any ideas on what it exactly ?!
The defender is pulling vaguely to the left and suffering from light torque steer , could this be the cause ? All bearings and swivel pins are good , suspension set up is only a few weeks old. A bit of slop in diff (1/4 of a turn) and a tad clunky. Other than that no awful grinding noises.
I’m falling out of love with this particular defender !
Thanks
Rich
Post #749699 7th Jan 2019 9:07am
Bluericky
Should add that it stops pulling left when you dump the clutch
Post #749700 7th Jan 2019 9:09am
When you say "housing" do you mean the swivel housing, or was it in the end of the axle tube?
If it was in the axle tube, this, together with the characteristics you describe, would make me suspect that the front diff is breaking up. Assuming that it is the Defender in your avatar and therefore a 2009 110, it probably has a single cross-pin in the front diff (a two gear diff, later models had a much stronger four gear diff). The single cross pin or two-gear diff is weak for a 110 (or 130) and is a common failure, generally with some undesirable steering effects (when mine failed the diff locked solid, making it virtually impossible to steer the vehicle).
It is possible to get some idea of the state of the diff my looking through the oil filler hole in the axle case, but the only sure way is to drop the diff out of the axle. If you are finding metal fragments in the axle case and you have odd steering effects, I would suggest that this would be a sensible course of action.
The photos below show my diff after it failed. Note the elongated hole in the carrier where the cross-pin is supposed to be, and the damage to the teeth of the differential gears. In this case the cross-pin broke in two, dropped into the differential gear cluster locking it completely and breaking many teeth of all the differential gears. Fortunately although this locked the diff solid making steering next to impossible, it didn't lock the axle solid. Landrover of course maintains that there is no problem with these diffs and that it was purely coincidental that later 110 and 130 Defenders have a stronger front diff.
Post #749713 7th Jan 2019 10:54am
Bluericky
Thank you Blackwolf for your in depth reply .
Yes it was inside the axle tube itself , just sitting on the edge with half a dozen much smaller fragments (1mm ish ) !
Ironically this front diff was an entire axle replacement from a used 2012 110 so I imagine that would be the stronger 4 pin you speak of ?!
I have my original diff in the broken axle housing so I could swap that over or I suppose or buy a reconditioned unit from Ashcroft or the like.
Out of interest who do you use in the west country for your work or do you do most of it yourself ?
Post #749719 7th Jan 2019 11:05am
I do my own work, sadly I don't trust anyone else to do it (at least not anyone I can afford)!
You should certainly be able to tell if you have the two gear or four gear diff by peering through the filler hole, they are very different in appearance. The two gear diff has a very open carrier (as in my photos) whilst the four gear is solid. If you can see the differential gears (I don't mean the crownwheel, of course) then it is a two gear diff.
I can think of no circumstances under which I would now fit a two gear diff in the front of any Defender, four is the way to go. If you old 2-gear diff is OK and you need a new one for your current axle, I would suggest either fitting the old one temporarily and using the broken one as the basis for an Ashcroft build (this presupposes that the broken one isn't so damaged that it can't be used) or use the old good one as the basis for an Ashcroft build.
When I changed mine, the cost of a fully-built Ashcroft ATB diff assembly bought outright was very much less that the cost of an exchange standard diff from Landrover.
it might as a fist step be worth draining the axle oil to see how much additional debris comes out, but the presence of any fragments at all in the axle tube is bad news.
Post #749722 7th Jan 2019 11:18am
Bluericky
Thank you Blackwolf I believe you talk sense ! I’ll drain it and let you know what I find but at the moment it doesn’t feel at all safe to drive , unpredictable steering isn’t at all ideal .
Will let you know how I get on
Post #749735 7th Jan 2019 12:14pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
It looks like a broken tooth from diff gear wheel - the smallest one. Las summer I was replacing both diffs on our Discovery 2 for lockers and both were nearly shot - in rear there were small chips on some wheels, front had tiny beak lines on all teeth and some metalic-like oil inside. it took me quite a long time to clean the axle tubes from small metal particles - first wiping then, than picking up the rest with strong magnet. If you don't have the oil drain plug with magnet, get one. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #749783 7th Jan 2019 5:35pm
Bluericky
Thank you madtom, i’ll definitely be cleaning out the axle casing .
Interestling I had to drive it locally this evening , up a very long steep hill , with my foot down on the accelerator the steering was really quite stiff until I eased off the accelerator at the top !
Diff out tomorrow
Post #749786 7th Jan 2019 5:48pm
LR90XS2011
what Blackwolf said diff probably on the way out, take a look at the Ashcroft ATB thread. DEFENDER 90 TDCI XS,
Post #749795 7th Jan 2019 6:58pm
Bluericky
Well Diff went today .
I’ve been caught up with things on the farm and hadn’t had time to switch it out , plus I was a little apprehensive as not done it before !
There was a crunch or two and all drive went. So I slipped it into diff lock and crawled up to the workshop .
Drained the oil and inspected the magnetic plug !!!! Here’s how it looked .
Post #756181 4th Feb 2019 12:37pm
Bluericky
Just starting to strip it down now !
Post #756182 4th Feb 2019 12:38pm
Caterham
I think it's fair to say you're going to find a problem Mr. Green
Post #756190 4th Feb 2019 1:01pm
Bluericky
Yup it’s cooked !
Post #756194 4th Feb 2019 1:20pm
Caterham
even with my limited mechanical knowledge I'd say that's less than ideal.
good luck with the rebuild. Thumbs Up
Post #756196 4th Feb 2019 1:22pm
Bluericky
Is the diff gasket necessary? Mine just appears to have copious amounts of rtv sealant around it . Could do both but would rather hear from experience
Post #756206 4th Feb 2019 1:35pm
Page 1 of 3 123>
