![]() | Home > Td5 > Running flat/ underpowered |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 ![]() |
Just ran a test on the MAF with multimeter & it’s showing 2v and going up when revving the engine.
Obviously my MAF was knackered. Still doesn’t seem as lively as when I had it mapped. Will it have gone into a learning mode whilst mine was knackered ? Had it unplugged for couple of days to, to see if that made any difference. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2193 ![]() ![]() |
Learning mode?
So youve driven it with the maf disconected? Any change? Ideally you need it pluged into diagnostics. How flat do you mean? Could be in limp mode. Instagram @defender_ventures Empire Tuning - Agent |
are getting 12v supply to maf :?:
Yes got 12v coming in. It’s actually around 14 when running.
Is the only way to get it out of limp mode to get a diagnostic tool plugged into it & code cleared ? Car does have a bit more go in it but doesn’t seem to go as well as when it was remapped by Alive. Maybe need a quick trip to go see Gary @ Alive. |
drinkdrinkdrop Member Since: 13 Sep 2016 Location: Surrey Posts: 76 ![]() ![]() |
Wastegate actuator is worth checking with those symptoms
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
+1 for checking wastegate is moving freely
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
All sorted now thanks fellas
![]() ![]() Fitted new MAF sensor & now showing 2v at idle. Rang Gary @ Alive to arrange to take it in to be looked at. Got to Alive & they checked everything over & all seemed good until he discovered my map had been wiped from the ECU when my local guy updated my software. Local guy thought he was doing me a good deed by updating everything after sorting my 3 amigos problem out. Anyway Gary has restored my map with more updated version & now it's running like a dream again. Has the oooomph back & pulls strong again. Thanks for all of your advice, much appreciated ![]() |
A MAF is not only broken if it is dead. I had one that gave about 40% lower readings.
Reading your symptoms I don't think it is the MAF. But I don't know what else it can be. So borrow a Nanocom and do a test drive and look at the readings. A td5 does not stay in limpmode. Everytime you start up the same problem has to be there to get in limp mode again. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Read above my reply Roel.
Problem all sorted now with explanation above. ![]() |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 960 ![]() ![]() ![]() |
Oh that Roel, always behind the times
![]() ![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Looks like we were typing at the same time.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
