Home > Maintenance & Modifications > Wiring help please |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1319 |
Is the switch lit permanently as you have connected the control box to a permanent live?
I am thinking you could break the fused + feed to the box and route it through a standard 30 Amp relay which is triggered by a low current feed from the main beam circuit. The relay would kick in when the main beam is switched on, and the switch from the LED controller box would then act as your isolator. You can pick up 12V automotive relays with base holders and wiring tails for next to nothing on fleebay. You would lose the switch lighting doing this, unless you figured out which of the three switch wires provides the lighting feed. This feed could then be tapped into the dashboard lighting feed. Probably better anyway, otherwise the switch will be lit all the time, even with the ignition switched off. |
28th Dec 2018 9:18pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
To be road legal spot lights are what are known as optional headlights. As such the spotlights should have light function R marked on the lens and wired through the main beam switch so they switch off simultaneously with main beam.
Without seeing the wiring diagram supplied with the wiring loom it can be a bit of a guessing game. To be road legal you will need a positive feed from the main beam switch to the illuminated switch so that when main beam goes to dip the spots switch off. Brendan |
28th Dec 2018 9:29pm |
Click image to enlarge you have three wire on your switch one 12v feed to the switch, one switched 12v return back and wire for neg for switch illuminated Last edited by dorsetsmith on 29th Dec 2018 9:58pm. Edited 2 times in total |
28th Dec 2018 10:23pm |
Emptywallet Member Since: 03 Mar 2018 Location: Alresford Posts: 31 |
Thanks all for your kind advice, however I still need a little more help.
Lights are now installed and working as they should via a single illuminated rocker switch which is only Illuminated when lights are switched on. I have wired them up exactly as the instructions provided by the loom. Sadly no relay pin outs. Click image to enlarge Whilst I had the dash out I spliced into the blue/white trace high beam feed. Next job is to work out how to replace the current rocker switch with a relay energised by the high beam feed. I also want to use a standard Land Rover driving lamp switch as kindly posted by Dorsetsmith. Any help much appreciated. |
29th Dec 2018 8:53pm |
I suspect your mystery box is actually a relay but the diagram posted by dorsetsmith above tells you exactly how to wire in a standard relay and a LR driving lamp switch. Darren
29th Dec 2018 10:19pm |
