![]() | Home > Technical > landrover puma 2.2 2013 |
https://www.technozen-electronics.co.uk/la...-services/
only one 12v power input to the alarm unit for indicator flashes out put so garage may be right and you have dry solder joint as you have tested form output pin on unit remove and repair good luck |
