Home > Technical > landrover puma 2.2 2013
dcpallets
when fob is pushed to activate lock only left hand indicator flashes, same happens when unlocking to. tried test light on alarm box which operates right hand indicator, and the test light doe's not light up. someone told me at a garage could be a dry solder joint?
Post #747768 28th Dec 2018 5:22pm
dorsetsmith
https://www.technozen-electronics.co.uk/la...-services/
only one 12v power input to the alarm unit for indicator flashes out put so garage may be right and you have dry solder joint
as you have tested form output pin on unit remove and repair good luck
Post #747775 28th Dec 2018 6:08pm
