Home > Technical > Dreaded intermittent power loss |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
re P1602 - battery is on its way out I think. That could be the cause of this code.
Battery is the original from Oct 2009 when truck was first registered. Its a MY2010 USW - XS spec 110. |
19th Dec 2018 9:59pm |
Also, could a dodgy EGR cause intermittent power loss issues?
Mine has been noisy whilst driving but still does the five chukka chukkas when turning off the engine. |
19th Dec 2018 10:30pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20453 |
I would say looking at your DTC’s it will be the IPAC.
Record all the codes on paper and keep safe then clear them, before doing this check the connector plug to the rear is secure. See what DTC’s if any are logged after that. If there continues to be issues IPAC related, check the solder joints on the PCB and or try another IPAC cluster. I would doubt the battery or EGR has anything to do with it as you’d get EGR codes or low voltage signal codes. Also eat in mind the VCV has no MIL or DTC’s that logs when there could be issues there. That would however, not cause the IPAC issues that are logged DTC’s. Occasionally poor earthing can cause all sorts of phantom issues too. Like the time my transfer box earth strap was loose and when I would brake or indicate every light would light up like an Christmas tree internally or externally in different mannerisms. Looking back afterwards it was rather entertaining but certainly not when it started out on the road! As far as I’m aware the IPAC can be just changed over as all vehicle info is ECU stored. Unless anyone can correct me on this, if so please feel free. Personally I’d try the easiest cheapest options first. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
19th Dec 2018 11:18pm |
Thanks Steve, will check the IPAC connector and take it from there
These DTCs cannot be erased as they are "permanent" ones, meaning only resolution of the error in the relevant module will clear them. |
19th Dec 2018 11:30pm |
Unplugging and re-plugging the IPAC seems to have cleared all codes except for the following:
FAULT 1 OF 2 ECU: Instrument Pack CODE:P1602 Immobilizer/engine control module communication error (NOT TESTED DTC) FREQUENCY MODULATION/PULSE WIDTH MODULATION FAILURE - NO SIGNAL. FAULT 2 OF 2 ECU: Instrument Pack CODE:U0401 Invalid data received from engine control module/powertrain control module (NOT TESTED DTC) ALGORITHM BASED FAILURE - EVENT INFORMATION. |
20th Dec 2018 11:40am |
sam7345 Member Since: 10 Feb 2019 Location: Cornwall Posts: 6 |
Hello, I have all these codes at present and my defender will not start.
Did you ever get to the bottom of it? Cheers sam |
10th Feb 2019 9:29pm |
Haven't had time to look into it = not used the car since the issues.
Will have a look when weather improves |
10th Feb 2019 9:32pm |
