Home > Technical > 200tdi Disco 1 suddenly stopped |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2647 |
Remove the oil filler cap then crank the engine and watch to see if the rocker arms move just to rule out the belt what with that being the last thing you changed.
16th Dec 2018 8:38pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
You might find answers from watching this:
17th Dec 2018 9:14pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
Stop solenoid?
Weak pump? |
17th Dec 2018 11:01pm |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 |
I have taken the stop solenoid plunger out, cracked pipe at fuel filter outlet and got fuel flow when cranking the engine, rockers are operating so no timing belt failure therefore none of these are faulty. I am gettig fuel at the injector inlet pipe but not sure how it should flow, so I have disconnected the metal injector pipe at the injector, cranked the engine and I get a squirt of fuel from the pipe just not sure if it should be more aggresive therefore lack of pressure. 1990 200tdi conversion 90
17th Dec 2018 11:17pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1841 |
Maybe not 100% what you're after, but I happened to watch this video last night, and there's a bit where he fits a new lift pump, and has diesel spraying out of the filter bleed screw. This might give you an idea of the sort of flow that's normal/needed.
https://m.youtube.com/watch?v= Maybe not so much use if the engine isn't running though.... Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
18th Dec 2018 9:38am |
bigfatsi Member Since: 07 Sep 2018 Location: Teesside Posts: 48 |
Ah I remember having those days.
9/10 it's the lift pump. I have had leaking fuel pipe joints and even a holed pick up pipe before though. And a dodgy fuel filter connection. Can you try the old fuel can on the roof trick for diagnostic? Or a clear pipe in line to check for air? S |
18th Dec 2018 11:38am |
Injectors don’t look too clever?
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 1990 200tdi conversion 90 |
18th Dec 2018 9:32pm |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 |
What the heck happened to those injectors?
19th Dec 2018 1:59am |
Getting them tested today, not sure why they are like this though 1990 200tdi conversion 90
19th Dec 2018 11:49am |
Hmmm injectors tested like new, running out of ideas now, guess check timing next but do not understand how the timing belt could slip if that’s the problem. 1990 200tdi conversion 90
19th Dec 2018 3:30pm |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 827 |
change fuel filter and swop lift pump
19th Dec 2018 4:56pm |
I changed the fuel filter and I inspected the old one, it was in excellent condition. I am about to check timing, removing crankcase case.
But before I do can anyone tell me if a faulty or inefficient lift pump would cause this situation? 1990 200tdi conversion 90 |
19th Dec 2018 5:34pm |
I'm afraid I can't be definitive, just because I can't remember the details.
I remember having poor running, or starting issues which were eventually traced to the lift pump. The symptoms weren't as bad as yours seems to be, but perhaps it was summer and the fuel was thinner/lighter? I think the 'main' pump will draw fuel through, even if the lift pump isn't working but everything else would need to be in good order. Sorry - not much help. On the plus side, it's not an expensive part.... Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
19th Dec 2018 7:43pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2227 |
The engine will pull well enough without the lift pump as the injection pump will pull fuel through. If knackered though, you will notice the difference when you replace it.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
19th Dec 2018 9:36pm |
