Home > Maintenance & Modifications > Wheel Spacer watch out
Co1
Had fitted wheel spacers recently and got a bit of a wobble after fittingfrom the fronts. Turns out that it is the drive member nuts that were catching the alloys as the wheels went on now that they are 36degrees out. I was going to take them out (probably still will) and re torque them and hope the flats can line up better so that they don’t catch the alloy but I had a stinker of a day and snapping a drive member bolt off would have been the icing on the cake!!
Thought it worthy of sharing to save anyone making the same mistake.
Post #746178 17th Dec 2018 6:45pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Thumbs Up
Post #746181 17th Dec 2018 7:13pm
rallysteve
You would be better swapping out the drive flange bolts for capheads.
Post #746193 17th Dec 2018 8:03pm
This is an age-old problem with 30mm spacers and Boosts, the (permanent) solution is to replace the drive flange bolts with hex socket head capscrews (widely and incorrectly known as "Allen bolts").
Edit: simultaneous post!
Post #746194 17th Dec 2018 8:04pm
Co1
Great call. Are they M10?
Post #746196 17th Dec 2018 8:22pm
rallysteve
M10x1.5 45mm length. Either grade 10.9 or 12.9 will do the job nicely. Loctite and tighten to 65Nm.
Post #746203 17th Dec 2018 8:42pm
Co1
Cheers Steve, much appreciated.
Post #746204 17th Dec 2018 8:46pm
Mine are 12.9 and you can use a spring washer instead of Loctite, much less risk of bolt breakage for mainentence and they won't go anywhere.. TheThunder Rolls🇬🇧🇺🇸
Post #746213 17th Dec 2018 9:36pm
rallysteve
We will have to diagree here. Lock spring/split lock washers are pretty useless.
If not using loctite you might as well just torque them up, you will stand a better chance of getting near the target preload without a lockwasher. Also a standard lockwasher designed for a Hex Head bolt/set screw is too large diameter for a Socket Head capscrew and is possible that it will interfere with the alloy in the same way that the current bolts do for the OP
Post #746227 17th Dec 2018 10:36pm
The spring washers I used were the exact dia of the hex cap head bolts I used.
Perhaps you are thinking of a different type to what I am?
Blackwolf I believe uses the same set up as me with no problem and alleviates the issue that the OP had originally complained about.
(In fact recommended this set up to me, and does indeed work well.)
Bear in mind there are different types of washers, and I used 'spring washers' and not 'lock washers'. TheThunder Rolls🇬🇧🇺🇸
Post #746234 17th Dec 2018 11:12pm
miker
Diameter excepted, I am also fairly convinced that spring washers do very little, based on the research I've done.
Post #746239 17th Dec 2018 11:24pm
jst
Nord locs work well. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #746253 18th Dec 2018 6:56am
rallysteve
We seem to be over-complicating matters here. The most important thing here is to ensure that the bolts acheive as close to optimum preload as possible. This is done by using a torque wrench in this application (which itself is massively innacurate and dependant on so many factors).
Vibration loosening shouldnt really be an issue on the rotation of the hub, your wheel nuts dont use any form of supplementary locking means and they are a little more critical.
Drive flange bolts usually break as they have been over or under torqued or because someone has just wedged some rusty bolts back into a rusty thread still full of old threadlock and jammed them in.
Just run an M10 tap through the holes, use some nice new bolts with or without threadlock and torque them to 65Nm.
Post #746265 18th Dec 2018 8:00am
jst
Possibly, but we found as you ran larger tyres 37, 40s and 44s that if drive member bolts werent wired or nord locked then they came undone, was just passing on a solution. it worked for us. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #746292 18th Dec 2018 12:56pm
JST- I was going to me mention your solution but I couldn’t remember who it was that used the Nordlocs.
Of course this was yourself.
So there are multiple solutions possible for the OP to decide what they might like to chose to do TheThunder Rolls🇬🇧🇺🇸
Post #746304 18th Dec 2018 2:45pm
