![]() | Home > Puma (Tdci) > Diesel leak n/s of engine |
Phid Member Since: 25 May 2018 Location: Dorset Posts: 85 ![]() ![]() |
Thanks for all of your help.
It is leaking from the fuel temperature sender. I’ve tried to tighten it but it is right so assume I need to replace the unit or just the washer. Can you buy the washer on it’s own? Is it likely that this leak is causing a pressure drop and stopping the engine starting? If I replace the sender with the fuel system need bleeding? Thanks again |
Had another looks and tried to tighten the two Alan bolts next to the VCV. They were not nipped up. I have tightened them a bit and retried to start. No leak. It must have been running down onto the fuel temp sender. I need to try and tighten more (longer Alan keys?).
However still not starting - could that be air in the system or still need to tighten the bolts? How do you bleed if air in? |
![]() Click image to enlarge Last edited by dorsetsmith on 11th Jan 2019 9:35am. Edited 3 times in total |
8nm - that’s not very tight. No surprise they came loose. It’s good they don’t have to be too tight as they’re a pig to access.
That bleeding doesn’t look straight forward unfortunately 😬 |
Fuel System - General Information - Low-Pressure Fuel
System Bleeding from work shop manuel link below https://1drv.ms/b/s!AtZSoWFHDgnGkW4lPCyeH9UgniUW Last edited by dorsetsmith on 11th Jan 2019 9:58am. Edited 2 times in total |
That looks easier - just need the special tool.
Thanks for all the help |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20638 ![]() ![]() |
Dorsetsmith - Thank you for that VCV screenshot also.
May prove useful to me shortly. ![]() ⛽️🛢️⚙️🧰💪 |
Got it started however still leaking.
Is it possible to buy just a replacement gasket and o ring for the fuel vapour valve - ie not the whole unit? I’ve done a search but can’t find the separate parts. Thanks |
hole thing only
VCV Kit part numbers Landrover part LR009837 Ford part 1 514 885 (6C1Q 9358 AB) or get sheet gasket paper make one and sort out Nitrile O-Rings ![]() |
