Home > Td5 > Inward facing rear seats in a 90
Jez676
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Good evening all,
I have put a wanted request in the for sale section for some td5 rear inward facing seats as mine have been removed at some point by the previous owner. If I can’t find any used ones I will have to go new but searching on here and searching Google I can’t find any part numbers and indeed a list of what I need. I have the bars fitted on both rear wheel box’s but nothing else. It is a genuine station wagon and I want to keep it genuine parts if I can.
Any suggestions or advice welcomed
Jez
Post #745091 11th Dec 2018 12:39am
Green Machine
This will help you out with part numbers (scroll down to the bottom on left for Td5):
http://cat.lrparts.ru/
Seems from a quick look that you can't buy the whole seat assembly as one item with all the fittings etc. You would have to buy everything individually, and as these are Td5-specific parts (i.e. not used on the newer Puma Defenders), they are likely to be pretty expensive.
Your best option for genuine ones would be trying to find a set from a scrapped Td5 SW, or a set someone has removed. eBay is probably the best starting place.
Alternatively, Exmoor Trim do their own version of these seats, which are very similar to the genuine items:
https://www.exmoortrim.co.uk/our-models/de...p-ups.html
(I have no experience of them, so can't comment on quality / fitting etc. I just know they do them). 2005 Td5 | 90 Station Wagon | Tonga Green
Post #745148 11th Dec 2018 12:50pm
Green Machine
Are the seatbelts and buckles still there? Or have these been removed?
If the seatbelt mounting bars are still there, are the tubular strengthening bars that tie back to the rear crossmember still there in the wheel arches? Guessing they will be. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #745150 11th Dec 2018 12:53pm
jst
If you end buying new, these exmpor ones are much more comfortable https://www.exmoortrim.co.uk/inward-facing-fold-up.html Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #745152 11th Dec 2018 1:03pm
Jez676
Yes the bars and the bulkhead strengthened are still there but no seatbelts or seats.
I’ll have a look at the parts catalogue in a minute as I need to work out if the inward facing seats in a 110 td5 are the same as a 90 as I have been offered some from my wanted add.
Thanks Green machine👍
The exmore ones look good but I’m on a tight budget and £600+ is more than I can afford at the moment, but thanks for the spot JST
Post #745180 11th Dec 2018 3:44pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Parts numbers here.
https://www.lrworkshop.com/diagrams/land-r...ts/seating 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #745181 11th Dec 2018 3:53pm
Jez676
Well it looks to me from the parts lists that the 90 inward facing seats are the same as the 110 td5 inward facing seats as there is no differation stated.
Does anybody know anything different? Are they definitely the same?
Many thanks for all of your time in helping me out by the way.
It’s very much appreciated
Post #745186 11th Dec 2018 4:06pm
4RF RDS
My own personal experience is that they are in fact interchangeable. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #745187 11th Dec 2018 4:09pm
Yes, they're definitely the same. It's not just TD5 seats, either. Whilst the fabric may vary, the seat design was pretty much unchanged for the entire production run, up to the introduction of the Puma model. Darren
Post #745192 11th Dec 2018 4:29pm
Jez676
Brilliant, I just need to find some now then!
Many thanks everybody for your help.
Post #745221 11th Dec 2018 7:19pm
