Home > Td5 > Inward facing rear seats in a 90 |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
This will help you out with part numbers (scroll down to the bottom on left for Td5):
http://cat.lrparts.ru/ Seems from a quick look that you can't buy the whole seat assembly as one item with all the fittings etc. You would have to buy everything individually, and as these are Td5-specific parts (i.e. not used on the newer Puma Defenders), they are likely to be pretty expensive. Your best option for genuine ones would be trying to find a set from a scrapped Td5 SW, or a set someone has removed. eBay is probably the best starting place. Alternatively, Exmoor Trim do their own version of these seats, which are very similar to the genuine items: https://www.exmoortrim.co.uk/our-models/de...p-ups.html (I have no experience of them, so can't comment on quality / fitting etc. I just know they do them). 2005 Td5 | 90 Station Wagon | Tonga Green |
11th Dec 2018 12:50pm |
Are the seatbelts and buckles still there? Or have these been removed?
If the seatbelt mounting bars are still there, are the tubular strengthening bars that tie back to the rear crossmember still there in the wheel arches? Guessing they will be. 2005 Td5 | 90 Station Wagon | Tonga Green |
11th Dec 2018 12:53pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8136 |
If you end buying new, these exmpor ones are much more comfortable https://www.exmoortrim.co.uk/inward-facing-fold-up.html Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
11th Dec 2018 1:03pm |
Jez676 Member Since: 24 Feb 2013 Location: North Devon Posts: 178 |
Yes the bars and the bulkhead strengthened are still there but no seatbelts or seats.
I’ll have a look at the parts catalogue in a minute as I need to work out if the inward facing seats in a 110 td5 are the same as a 90 as I have been offered some from my wanted add. Thanks Green machine👍 The exmore ones look good but I’m on a tight budget and £600+ is more than I can afford at the moment, but thanks for the spot JST |
11th Dec 2018 3:44pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 952 |
Parts numbers here.
https://www.lrworkshop.com/diagrams/land-r...ts/seating 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
11th Dec 2018 3:53pm |
Well it looks to me from the parts lists that the 90 inward facing seats are the same as the 110 td5 inward facing seats as there is no differation stated.
Does anybody know anything different? Are they definitely the same? Many thanks for all of your time in helping me out by the way. It’s very much appreciated |
11th Dec 2018 4:06pm |
My own personal experience is that they are in fact interchangeable. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) Last edited by 4RF RDS on 11th Dec 2018 5:22pm. Edited 1 time in total |
11th Dec 2018 4:09pm |
Yes, they're definitely the same. It's not just TD5 seats, either. Whilst the fabric may vary, the seat design was pretty much unchanged for the entire production run, up to the introduction of the Puma model. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
11th Dec 2018 4:29pm |
Brilliant, I just need to find some now then!
Many thanks everybody for your help. |
11th Dec 2018 7:19pm |
