![]() | Home > Puma (Tdci) > Will a rear diff from a 90 fit the rear of a 110? |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 ![]() ![]() ![]() |
Check i) if it is a 4-pinion (2-pin is weaker and not designed for a rear 110"), ii) The front facing nose might be different so you might have troubles with rear prop lenght and bolt pattern. iii) spring seaters.
Hope it helps to decide Puma 110" SW ............................................................. Earth first. Other planets later |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
99% it wont fit, as only a few 90s were fitted /w a 110 compatible one. Yes, you can, BUT unless you are 5,000 miles from a workshop, dont do it.
