Home > My Defender > My 1984 Ninety V8 Slate Grey
Page 2 of 12 <123 ... 101112>
Co1
Like it!! More pics needed!
Post #744670 8th Dec 2018 2:38pm
williamthedog
Those wheels suit it down to the ground. Still looks old school and nothing blingy Thumbs Up
Post #744677 8th Dec 2018 3:50pm
Slideywindows
Very nice James, a V8 Ninety at last. Thumbs Up
Welcome to the early Ninety set.
Now you have the V8, maybe it needs a little run over the border to North Essex? Whistle
Post #744751 8th Dec 2018 10:51pm
JOW240725
Sounds like a plan Slidey, but non-scratchy with this nice 'new' one. Whistle Embarassed James
Instagram @suffolk_rovers
Post #744772 9th Dec 2018 9:46am
JOW240725
Tried fitting the new wheel today and discovered the studs only come about half way thru the nut, so looks like I'll need extended wheel studs Big Cry
 James
Post #744826 9th Dec 2018 5:07pm
seriesonenut
Hello James
I'm sure someone will be along to offer advice. My understanding is you can retro fit Wolf wheels regardless of the stud length. The military did this to earlier vehicles and just specified a higher torque setting.
Old Red ran a set for many 1000's of miles with no issues and they are on my tdci now. The studs do not come to the end of the nut and I have torqued them up to a higher setting.
Great looking 90 Thumbs Up 2010 XS USW
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #744831 9th Dec 2018 5:13pm
discomog
Thread engagement length is a critical factor, particularly with regards to road wheels. As a minimum the thread engagement length should be equal to or greater than the stud diameter. For example if the stud diameter is 12mm then the nut must engage for a minimum of 12mm. It's another urban myth that the stud thread has to extend beyond the end of the nut. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #744835 9th Dec 2018 5:33pm
Romadog
........and it's expensive buying 20 of the longer stud too. They extend much further than the end of the nut......nearly enough to put a 101 style step on the wheel as well ......yes I know 101 has 6 studs rather than 5 Thumbs Up
Post #744837 9th Dec 2018 5:44pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Nice one and a proper colour too, mind you I am biased Whistle Welcome to the early Ninety club Thumbs Up
Post #744857 9th Dec 2018 6:54pm
JOW240725
Sounds like I'm going to have to try again and see what it looks like. Thanks all.
Thanks Defender9, not a factory V8 but close enough Very Happy James
Post #744867 9th Dec 2018 7:28pm
LR Sam
Congrats James! Looks lovely and I am sure you will add to it!
Can I ask what tyre size you went for and which model? I can see they are Coopers. Cheers
Post #744869 9th Dec 2018 7:36pm
JOW240725
Thanks. The tyres are Cooper ST Maxx 235/85R16. They are standard size but look huge next to the little 205's.
 James
Post #744871 9th Dec 2018 7:46pm
LR Sam
They do look great!
Post #744875 9th Dec 2018 8:01pm
Slideywindows
My Ninetys are on original spec 205's, as the little 2.25 petrol engines don't seem like larger diameter tyres, but your V8 should have no trouble pulling the larger diameter.
Is your speedo reading still accurate?
Post #744876 9th Dec 2018 8:05pm
OJ
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Very nice looking Land Rover, great job Thumbs Up
Post #744877 9th Dec 2018 8:07pm
