![]() | Home > My Defender > My 1984 Ninety V8 Slate Grey |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3698 ![]() ![]() ![]() |
Like it!! More pics needed!
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Those wheels suit it down to the ground. Still looks old school and nothing blingy
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Sounds like a plan Slidey, but non-scratchy with this nice 'new' one.
![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Tried fitting the new wheel today and discovered the studs only come about half way thru the nut, so looks like I'll need extended wheel studs
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1231 ![]() ![]() |
Hello James
I'm sure someone will be along to offer advice. My understanding is you can retro fit Wolf wheels regardless of the stud length. The military did this to earlier vehicles and just specified a higher torque setting. Old Red ran a set for many 1000's of miles with no issues and they are on my tdci now. The studs do not come to the end of the nut and I have torqued them up to a higher setting. Great looking 90 ![]() 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2533 ![]() ![]() ![]() |
Thread engagement length is a critical factor, particularly with regards to road wheels. As a minimum the thread engagement length should be equal to or greater than the stud diameter. For example if the stud diameter is 12mm then the nut must engage for a minimum of 12mm. It's another urban myth that the stud thread has to extend beyond the end of the nut. Defender 90XS SW
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
........and it's expensive buying 20 of the longer stud too. They extend much further than the end of the nut......nearly enough to put a 101 style step on the wheel as well ......yes I know 101 has 6 studs rather than 5
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
Nice one and a proper colour too, mind you I am biased
Sounds like I'm going to have to try again and see what it looks like. Thanks all.
Thanks Defender9, not a factory V8 but close enough ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
LR Sam Member Since: 08 Nov 2012 Location: Yorkshire Posts: 235 ![]() ![]() |
Congrats James! Looks lovely and I am sure you will add to it!
Can I ask what tyre size you went for and which model? I can see they are Coopers. Cheers |
Thanks. The tyres are Cooper ST Maxx 235/85R16. They are standard size but look huge next to the little 205's.
They do look great!
Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1294 ![]() ![]() |
My Ninetys are on original spec 205's, as the little 2.25 petrol engines don't seem like larger diameter tyres, but your V8 should have no trouble pulling the larger diameter.
Is your speedo reading still accurate? |
OJ Member Since: 23 Nov 2018 Location: North of Edinburgh Posts: 121 ![]() ![]() ![]() |
Very nice looking Land Rover, great job
