![]() | Home > Maintenance & Modifications > Flatdog / halo LED wiring connectors |
Deutsche connectors are by TE and they do a wide range of different connectors. Either have a google and see if you can identify the series they have used. Many companies do them and you be looking at about a fiver each when you include VAT and carriage. If you are uncertain about the actual connector take it to your local auto sparkle who should be able to identify the actual connector and order it in if need be.
Normally the female connector is on the power input side. Logic being that the live contacts are ‘protected’ when the circuit is ‘broken’ Brendan |
