Home > Maintenance & Modifications > Flatdog / halo LED wiring connectors
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Being as Flatdog and HALO share the same body, lamps etc, does anyone know what connectors are on the ends of the LED bars? I think they are Deutsch connectors, anyone know, male or female connectors from the bars?
Need to buy or make a loom....
Post #744829 9th Dec 2018 5:10pm
leeds
Deutsche connectors are by TE and they do a wide range of different connectors. Either have a google and see if you can identify the series they have used. Many companies do them and you be looking at about a fiver each when you include VAT and carriage. If you are uncertain about the actual connector take it to your local auto sparkle who should be able to identify the actual connector and order it in if need be.
Normally the female connector is on the power input side. Logic being that the live contacts are ‘protected’ when the circuit is ‘broken’
Brendan
Post #744849 9th Dec 2018 6:27pm
