Home > Puma (Tdci) > Coolant temperature issue and limp mode (revisited)
Eduardo
Well,
Winter ends and the summer is comming and with that the infamous temperature issue... Confused
After change all the inexpensive things (the thermostat, put the Nakatenga's fan extension, etc) without solve the problem completely, I decide to buy a new uprated radiator from Allisport to solve the temperature problem definitely (I hope).
So the order is on the way (Christmass present for the Defender) ad should be installed during the 1st week of January to be tested during our summer (Jan-Feb).
If this doesnt solve the problem I will run absolutely out of ideas.
I will keep you informed
Cheers to all Eduardo
Post #743816 3rd Dec 2018 8:04pm
What fluid do you have in there? $W33T $0U7H3RN $UG4R
Post #743856 3rd Dec 2018 9:46pm
MK
Nor sure about Defender's water pump efficiency but today I was looking at my Hilux 2.5 and I could tell the rad is probably 20% bigger. Hilux engine is std no remap and around same power and torque figures. Though the intercooler is not in front of the rad.
Have you thought on adding an aux fan? You can probably fit a sender at your spec. Puma 110" SW
Post #743859 3rd Dec 2018 9:56pm
Eduardo
Ethylene-Glycol based coolant, local made compatible with TL 774F 50% dilution.
According to the manual should be Texaco XLC (also ethylene glycol) which is also compatible with the TL 774F in 50% dilution
Cheers Eduardo
Post #743874 3rd Dec 2018 10:41pm
Eduardo
Humm, if the new radiator fails, probably that should be the way...
Thanks Eduardo
Post #743876 3rd Dec 2018 10:42pm
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
Stupid question, have you changed the viscous hub?. No offense but you guys have no idea about hot weather, both our Defenders have worked in 50 degree Celsius heat for weeks on end, but the fan MUST work.
Post #744148 5th Dec 2018 10:26am
Eduardo
PAT303
Viscous was replaced around 2-3 years ago.
BTW the problems occurs only with heavy load (as a family of 6 with all the gears), at high temperatures (over 30°C), high speed (120 kph) in mild but long slopes (that are common here in Chile and probably not in Australia).
Otherwise temperature is not an issue.
Cheers! Eduardo
Post #744213 5th Dec 2018 3:26pm
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
Do you have a cat fitted, that would be the first thing to remove.
I have had the same problem as you and have put it down to exhaust temp under load.
Fit a pyrometer and keep an eye on it.
I can drive mine and make it boil or watch the temp on the real time analogue gauge I have fitted and back off when temps rise.
Mark
Post #744258 5th Dec 2018 8:32pm
PAT303
Eduardo wrote:
PAT303
Cheers!
Eduardo, my advise, cut some gills in the front guards like the Range Rover, what you want is more airflow through the rad, owners have done it here and it makes a huge difference. https://www.google.com.au/url?sa=i&sou...2908023534
Post #744292 6th Dec 2018 12:38am
PAT303
Look at the side vents in that link.
Post #744293 6th Dec 2018 12:39am
Naks
Are you using 6th gear or gearing down to 5th? --
Post #744302 6th Dec 2018 6:37am
hornet
Re: Coolant temperature issue and limp mode (revisited)
Eduardo wrote:
Well,
Cheers to all
Do you have (even slight!) loss of coolant? Do you observe the OBD temperature of the cylinder head?
Post #744332 6th Dec 2018 12:22pm
Grenadier
Eduardo, I had exactly the same problem as you. Hills, high air temp, revs. But the clue was hills (and suggestions from the forum members) that my coolant was low. Is yours at the right level? No blockages or air bubbles? It sounds so similar. I topped mine up and now keep a regular eye on the level, and never had the problem occur again. Also gave the MAF a clean at the same time, but coolant was the key, it was low. Add the hills and it just seemed to accentuate the 'level' whereas flat roads seemed to be ok. It was obviously on the threshold for the ECU to turn on the limo mode. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #744364 6th Dec 2018 5:57pm
Eduardo
Mark
I cannot take out the catalizer (MOT restrictions in the city)
I have also a temp readed connected to the ODB So I can low the gear when the temp goes up to 105°C but is quite anoying in special in the long trips. Eduardo
Post #744488 7th Dec 2018 2:12pm
Eduardo
PAT303 wrote:
Eduardo wrote:
PAT303
Cheers!
Thanks for the idea
If the radiator fails I will study to do it Eduardo
Post #744489 7th Dec 2018 2:14pm
