Home > Puma (Tdci) > Bunch of fault codes. what do they mean?
Naks
Gents,
Found this bunch of fault codes in Orxy, the first time ever. I was resetting it to the standard map for a dealer visit on Tuesday and saw the following fault codes:
U0155 - Lost communication with instrument cluster
U0300 - Internal control module software incompatibility
P0606 - Engine control module (ECM) processor - circuit voltage below threshold / watchdog failure / internal electronic failure / component internal failure
P1643 - Controller area network (CAN) link engine control module/transmission control module circuit/network - missing CAN signal high / low switch.
P0110 - Intake air temperature (IAT) sensor 1 circuit - signal erratic / circuit short to ground / circuit short to battery or open
P0234 - Turbocharger A over boost condition
P068A - Engine control module (ECM) power relay deenergized - too early
Any ideas on what these mean? Are they related to each other? --
Post #74370 5th Jun 2011 8:46pm
Lorryman100
I take it these came from the remap unit fault code reader? If so most of the electronic faults,U0155,U0300,P0606,P1643 and P068A are regulars that appear with the use of a remap unit and are untested dtc's which will clear on there own if you don't delete them. Normal and I wouldn't worry about them. P0234 is normal as all Turbo diesels have regular over and underboost conditions.
NANOCOM - PUMAENG.APP - PUMA ENGINE fault file
068A - 00
0606 - 49
internal
electronic failure
C001 - 88
High Speed CAN Communication Bus
1643 - 87
These are the faults recorded in the past that are on the desktop, I have the same faults as yourself and those files are in the sd card in the nanocom. Must remember to bring it in and update the desktop Embarassed
The funny thing is that when I get the faultcodes with the nanocom or alien tech remap unit I leave them and plug in the IDS and it doesn't register them at all Confused And it can show both tested and untested DTC's. So I am beginning to believe it is just glitches which arise when using the nanocom/alien tech boxes through differences in the code being employed by said units.
Post #74378 5th Jun 2011 9:13pm
dgardel
Italy
Re: Bunch of fault codes. what do they mean?
Naks wrote:
Gents,
Are you remapped? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #74389 5th Jun 2011 10:16pm
Naks
dgardel wrote:
Are you remapped?
Yes, BAS remap. I read these fault codes with the BAS unit.
Pete says not to worry, it's normal. --
Post #74394 6th Jun 2011 5:13am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I had those codes on mine when running the tune.
Post #74432 6th Jun 2011 11:23am
Naks
Weird though, this is the first time I have had any fault codes since I got the landy and applied the BAS remaps. --
Post #74433 6th Jun 2011 11:24am
dgardel
Italy
Naks wrote:
dgardel wrote:
Are you remapped?
send the DTCs list to Pete.
He made a lot of development and the new maps doesn't generate errors.
Tell him that is a my suggestion. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #74478 6th Jun 2011 5:03pm
