![]() | Home > Puma (Tdci) > Bunch of fault codes. what do they mean? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 ![]() ![]() ![]() |
Gents,
Found this bunch of fault codes in Orxy, the first time ever. I was resetting it to the standard map for a dealer visit on Tuesday and saw the following fault codes: U0155 - Lost communication with instrument cluster U0300 - Internal control module software incompatibility P0606 - Engine control module (ECM) processor - circuit voltage below threshold / watchdog failure / internal electronic failure / component internal failure P1643 - Controller area network (CAN) link engine control module/transmission control module circuit/network - missing CAN signal high / low switch. P0110 - Intake air temperature (IAT) sensor 1 circuit - signal erratic / circuit short to ground / circuit short to battery or open P0234 - Turbocharger A over boost condition P068A - Engine control module (ECM) power relay deenergized - too early Any ideas on what these mean? Are they related to each other? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Are you remapped? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Yes, BAS remap. I read these fault codes with the BAS unit. Pete says not to worry, it's normal. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
I had those codes on mine when running the tune.
Weird though, this is the first time I have had any fault codes since I got the landy and applied the BAS remaps. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
send the DTCs list to Pete. He made a lot of development and the new maps doesn't generate errors. Tell him that is a my suggestion. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
