Home > Puma (Tdci) > instrument Cluster and Clock Connectors
Pjembe
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
Doing a little bit of work behind the dash and I have come up with bit of a problem.... How do you disconnect the clock and the instrument binnacle connectors.
I have got all the other switch connectors disconnected OK just stuck with these last two. Is there some sort of secret latch mechanism?
Any advice on how to undo these connectors would be greatly appreciated and if any one has pictures, even better.
Post #743738 3rd Dec 2018 3:03pm
Martin
Site Admin
Instrument pack:
Push down on tab (green arrow). This releases the latch which you swing across (orange arrow).
Clock:
Push down on tab (green arrow) to unlock, pull gently on connector.
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #743768 3rd Dec 2018 4:58pm
Martin above has the ones detailed perfectly.
Regards the clock one a little screwdriver could be very useful, as I use one just to push the tab down carefully.
Otherwise it's very difficult to ouch it down due to the small area involved to push it with a finger. No Guts, No Glory.
Post #743777 3rd Dec 2018 5:24pm
Pjembe
Brilliant! Thanks guys
Post #743788 3rd Dec 2018 5:59pm
