Home > Puma (Tdci) > Instrument Binnacle |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
Hi,, With the 2 screws removed, the binnacle top panel will just pull off upward,, one, or maybe 2 plastic tags secure it,, !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
5th Jun 2011 9:44pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
I fitted the power unit in behind the drivers speaker (plenty of room in here and it is easy to get a live from the fusebox or feeding the cable through to the centre console for fitting to the cig lighter or the radio, I have an alpine bluetooth unit and the tomtom usb power converter box in to the right of the speaker) and fed the cable out and up the right side of the dash. The power lead then tucks in behind the top of the dash and into the windscreen mount. There is plenty of room as I have run the cable for the scangauge along the same route.
Originally I wanted to do the same as you and go through the top, but found out that the dash doesn't sit flush again with the power lead exiting through the top as it is a tight fitting unit. Click image to enlarge Click image to enlarge |
5th Jun 2011 9:45pm |
baldylocks Member Since: 23 Sep 2010 Location: Gods Own County Posts: 99 |
Thanks Guys. AFter fiddling about a bit today and persusing tinternet it will be a combination of the two as I've found a semi permanent mount for the tomtom and the dremel cut a nice little slot out of the edge of the plastic above the clock for my phone.
Gerry |
6th Jun 2011 4:17pm |
