Home > Tdi > Incorrect Water Temp Guage reading 300tdi
OJ
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Temp Sender 300 TDi engine swap from 200Tdi
This was a project Defender i took on which was not finished correctly by the previous owner, among a host of other things when the engine was eventually running I had a problem with a higher than expected reading on the engine water temperature gauge, initially i thought it may be a faulty thermostat or a blown cylinder head gasket, however, it seemed to be running reasonably well, the thermostat was removed and tested, the engine temperature was checked using a digital laser thermometer which confirmed the engine was not overheating.
Turns out there are two types of sender for the 300tdi, one has a Green band and one has a Black band, the correct sender in my case was the one with the Black band.
I fitted a new sender with the Black band (purchased from Steve Parker 4x4) and its working correctly now, In my case a Green band sender had been fitted which makes the temperature gauge read incorrectly high.
I’ve removed the viscose fan and in the process of converting to an electric fan, i will post up how this goes.
Old Jock
Post #742811 28th Nov 2018 5:43pm
Grouse
There are also differences in the gauges - on a 300tdi, anything other than the correct gauge shows it as running hot
Post #742836 28th Nov 2018 7:21pm
OJ
Cheers Grouse, The Defender was originally a 200Tdi now with a 300Tdi engine transplant, temp gauge readout seems to be ok now and about what i would expect
Thumbs Up
OJ
Post #742841 28th Nov 2018 7:29pm
OJ
Got a fan, themostatic switch and fused relay all for just over £60, made up some brackets to fit the fan to the radiator, all sorted, result. Thumbs Up
Cool Cool
Post #743232 30th Nov 2018 5:43pm
Norton
United Kingdom 1990 Defender 90 2.5 n/a Diesel ST Nato Green
I found 6 different sender options when I did an engine swap.
Post #744386 6th Dec 2018 8:29pm
OJ
6 different types, Amazing, if i was doing it again i think i would try to match the guage and sender, but that wouldn’t be as interesting Mr. Green
OJ
Post #744401 6th Dec 2018 8:58pm
