Home > Puma (Tdci) > Odd power loss |
John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106 |
Hi lads, I've an odd intermittent power loss on my 07 2.4 tdci, it drives fine most of the time but the odd time it looses power, as if it looses pedal with no power and struggles past 70kph but if I switch it off and on again it drives perfectly! I've changed all filters twice but it's still the same? There's no smoke, no blowing turbo noises either? I've replaced potentiometers in the truck accelerator pedals before but they gave a different symptom to this?
Any ideas? Cheers John For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
27th Nov 2018 7:24pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
Fault codes?
28th Nov 2018 6:59pm |
John64 Member Since: 10 Sep 2018 Location: Tayport Posts: 38 |
Mine was doing this. Eventually traced to slightly sticky actuator arm for turbo. Only sticking on last wee bit. Disconnected arm and worked it past sticky bit for a few minutes, that and a bottle of turbo cleaner in tank and it’s been fine.
28th Nov 2018 7:11pm |
No fault codes, or management lights, The vcv valve, i must Look into this and the actuator arm also.
Thanks for the replys Cheers John For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
28th Nov 2018 9:59pm |
Check the harness that runs to the turbo modulator, all the way from the ecu to the turbo. It is very common for this to chafe and short to the engine.
28th Nov 2018 10:35pm |
