Home > For Sale & Wanted > [For Sale] Mantec Swing Away Spare Wheel Carrier
Page 4 of 6 <123456>
Stu_XS
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
I have the same flat baseplate as you but if you look at the top right bolt of the ram you’ll see two holes which are for the retainer. Stu...
2013 Aintree Green 90 XS SW 2.2 Puma
Post #742541 27th Nov 2018 4:33pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Stu_XS wrote:
Thanks a lot Martin. I think I found the same file in the early hours of this morning and I also had a copy emailed by Dan this morning. Smile
A question though, I'm glad you're in the same boat, there is what seems to be a retainer or latch which is the rubber cup and ball. From what I can see the rubber would bolt on to the back plate using the right angled bracket included. However the back plate will sit flat against the rear door so there isn't the space to fit it.
You can see in the image below it is mounted near the piston but on a raised back plate and not the flat type included in the kits.
Looks like your missing the raised bracket. However even with the raised bracket, you need to drill through the door for the raised bracket to bolt through the back plate
The mantec kits on eBay come with everything for £120, where did you get yours from?
Post #742549 27th Nov 2018 5:37pm
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
I don't have that raised bit on mine which was a genuine LR one from Dan. It's too dark to get a good photo but the rubber bit appears to be fitted to the back of the swing away plate and not the door plate.
Post #742551 27th Nov 2018 5:53pm
Stu_XS
Interesting.
So you got both baseplates in the same package??
Mine is a Land Rover part from Duckworths although I suspect they are actually the same overstock being sold on eBay and originating from the MOD auctioneers as they also have the NATO stock number on the box. Manufactured by Mantec.
Have to say I'm more than annoyed with the part and the manner in which it was supplied. The adverts that Duckworths have placed here and including on their own website say they include full instructions, which they don't, and when I contacted Dan yesterday he has replied with the same MOD document as mentioned here which frankly I am sure they do not have the rights to distribute.
Perhaps Dan would like to comment for others.
 Stu...
Post #742553 27th Nov 2018 5:55pm
Stu_XS
Exactly the point I'm making. It seems that Duckworths are selling ex MoD stock passing it off as LR stock.
There is half of the rubber catch on the back of the swing plate and the other should be bolted to the door plate. Stu...
Post #742555 27th Nov 2018 5:57pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Bought mine at Peterborough show and still haven't got round to fitting it, I'll have to go in the garage this this weekend and see what's actually in the box
Post #742557 27th Nov 2018 5:58pm
X4CAC
Not sure this helps at all..!
The swing away part did have LR stamped on it and the back plate has mantec on it (which I didn't particularly worry about as I knew mantec had made them for JLR historically... or so I was told).
I did receive all the parts needed to fit mine, minus the instructions
Post #742559 27th Nov 2018 6:01pm
Stu_XS
Probably the same as the rest of us that have them from the various sources of Ex MoD stock Moneypit.
If you look at the pictures shared by Dan in the original post you can see the raised bracket used on the half door.
Marked red are the parts concerned with the second part of the rubberised catch and where I think it should be bolted, marked green is the corresponding part on the reverse of the swing plate.
 Stu...
Post #742560 27th Nov 2018 6:05pm
Badger110
Stu_XS wrote:
Interesting.
I did
Ebay advert ( gone up £10 since I bought it )
https://rover.ebay.com/rover/0/0/0?mpre=ht...3113686980
Post #742563 27th Nov 2018 6:10pm
X4CAC
Post #742564 27th Nov 2018 6:10pm
Badger110
Do these pics help?
This picture below doesn’t show it engaged as i disengaged the swingaway to take the pic
Post #742566 27th Nov 2018 6:17pm
Badger110
However I will add that with the raised bracket, the whole swingaway doesn’t sit flush to the door...without it, it probably will
Post #742567 27th Nov 2018 6:19pm
Stu_XS
Badger110 wrote:
Stu_XS wrote:
Interesting.
I did
It seems to be noted in your sellers details that they include both baseplates for each eventuality. I think you have done the obvious thing in realising that to fit the buffer/retainer you need to sit back from the door plate however I think you have inadvertently (or knowingly) used the plates for both installations. Stu...
Post #742568 27th Nov 2018 6:21pm
Badger110
I used both so the load is spread when pulling the door open...otherwise you rely on the 3 of the 4 bolts of the raised plate ( the top right bolt can’t be fitted as it fouls the central locking mechanism )
Post #742569 27th Nov 2018 6:23pm
Stu_XS
This is the part I am interested in as it seems to me to be in place to latch in the swing arm when closed and should prevent rattling.
 Stu...
Post #742570 27th Nov 2018 6:24pm
