![]() | Home > Puma (Tdci) > Code U0428 Invalid data received from steering angle sensor! |
Does yours have the DSC button? Models with that feature had a slightly different steering wheel as part of the system so your aftermarket(?) wheel probably isn't compatible. Darren
West Yorkshire Lofty Member Since: 09 Mar 2014 Location: Dumfries and Galloway Posts: 116 ![]() ![]() ![]() |
Cheers LandRover Anorak, yes mine does have the DSC button!
I must admit none of the aftermarket suppliers mentioned this when purchasing the Moro steering wheel? Cheers WYL 2015 90 Keeper 2005 R300 Keeper 2019 XC40 Shopping Trolley 2008 110 XS Utility (Friday Build) Gone! |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
Does the indicator self cancelling work?
Morning Martin, the indicator cancelling works but it is not 100%.
Seems a bit biased to the right! Cheers WYL 2015 90 Keeper 2005 R300 Keeper 2019 XC40 Shopping Trolley 2008 110 XS Utility (Friday Build) Gone! |
That'll be it then. The angle sensor is telling the DSC system the car is steering right, however it knows from the wheel sensors and yaw sensor that it isn't.
Have you got the original wheel? ![]() ![]() |
Evening Martin, thanks for the info. Unfortunately the original steering wheel went a long time ago. What your suggestion? Is it time to take it to the garage?
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 ![]() ![]() |
Just needs the steering angle sensor calibration done - any good independent will have suitable kit to do this. IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2533 ![]() ![]() ![]() |
I was toying with the idea of fitting a Moto Lita and Optimil quick release hub to my Defender 2015MY which is fitted with DSC. Has anyone with a 2015MY fitted the above and more to the point will the DSC still work? (apologies for tagging onto your thread WYF). Defender 90XS SW
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
I have that fitted to my 2015 with DSC with no problems
![]() 2008 SVX 90 2000 XS TD5 90 |
Sulisuli, That's good news, thanks for that. Defender 90XS SW
