![]() | Home > Maintenance & Modifications > VGS privacy glass to gullwing conversion |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
that's looking quite nice.. Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 722 ![]() ![]() ![]() |
Excellent progress. A toffee wheel in a drill will get that adhesive off.
I got one to remove some old sikaflex and it made light work of it. Instagram: L90andy My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
Will that work? the remover told me it’s very hard to remove with a wheel... but, could be worth a try
![]() Thanks |
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 ![]() ![]() ![]() |
Might also be worth a bit of WD40 and a bit of elbow grease... I've removed all the decal adhesive using that approach... anything that was left over had a bit of G3 scratch remover paste dabbed on.
A toffee wheel will make the job a lot easier and quicker if you've got one to hand but I've used the above approach loads of time with no detriment to the original surface. |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
I have used "sticky stuff remover" quite successfully on residues, although not on the area you have left.
Available from Amazon and B&Q. Might be worth a try. |
This silicon bonding is mean stuff.. I have a toffee wheel, no harm to try it... heard WD40 has a way of softening up silicon, but this stuff VGS use is aircraft grade bonding, apparently.
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Much better! Nice job. Instagram @defender_ventures
Empire Tuning - Agent |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
Why not contact VGS and ask them what they use? 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
I did, they wouldn’t say what they used, the guy who removed them, windscreen professional, said it was “industrial strength”
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3349 ![]() ![]() ![]() |
Nice one. Looking better already.
Autoglym tar remover may get the worst of it off. |
The problem with removing the adhesive if it’s been applied correctly is that a primer should have been applied to the paint first, so you may end up having to paint the panels if the primer bonded properly to the paint. Ray
Yep, VGS installed them, before I got it. It’s been primed and it has etched into the paint in places, as it’s supposed to. They were never supposed to be removed, as VGS told me when I asked them. So, some of the bonding has gone, but, think it’s got to go in and get sorted.
![]() Thanks for all the suggestions... Update on progress at weekend when the rears come off |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
Screwfix sell a product which dissolves silicon bonding material
