Home > Td5 > A tapping sound. |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
Good day all.
So before I trouble my mechanic, let see if you lovely knowledgeable people can point me in the right direction. So on my way home from the NEC yesterday I noted a tapping sound. At the NEC I loaded up the truck, got the wife and in-laws seated & started up The Duchess, we started to poodle home, creeping out the car park, and roads, and as I was about to go on the roundabout before the motorway I gave it a bit of welly to get up to speed... It might have nothing to do with it. But im sure after that, it was then that the tapping noise started seemed to start, or at least got load enough for me to notice it over all the other noise.... And another note - The tapping seemed to change pitch and speed dependant on how hard I accelerated.. I was tired after an early start, long drive & long day shopping, and a long drive home, so it could all be in my head.. This morning the tapping was still there, but not as prominent... I will have a listen on the way home too, and add any changes or worthy notes.. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
26th Nov 2018 2:49pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
Exhaust manifold gasket blowing?
26th Nov 2018 2:53pm |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 822 |
Is it dependant on speed or by revs?
If it’s revs then its engine or exhaust related, if it’s speed related then it’s drivetrain related. Also just check that it’s not something actually in the cab, I kept hearing a squealing but it’s passenger seat / battery latch related, and a vibration from the rear was also something in the load space. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
26th Nov 2018 3:44pm |
Thanks guys, ill double check on my way home from work, and update you..
yesterday it definitely sounded like it was in front of me, in the engine bay.. Thanks for the heads up with the speed or revs comment, that's helpful, and ill be listening out on the way home.. I have heard the tapping on other diesels before, and always wondered what makes that tapping noise... Well im about to find out lol Thanks again guys Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
26th Nov 2018 4:04pm |
Hi all,
On the way home the engine sounded much better, no tapping out of the ordinary.. I had the flaps open at times and all I could hear was general engine noise. I'll keep you updated as the week goes on. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
26th Nov 2018 6:58pm |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 |
On mine it is Small drumming her fingers on the dash, wanting to get home for her cup of tea faster
1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
26th Nov 2018 7:12pm |
Lol. Regards
26th Nov 2018 7:57pm |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
if the tapping is speed related, is it coming from the instrument panel area? If so it may just be your speedo cable needing some lubrication or pushing home firmly. A dab of grease on the instrument end may quieten it. if you have had the binnacle off lately the cable can get pulled away from the speedo. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
27th Nov 2018 12:11pm |
Thanks for the info Jeffersj. this morning it was all quiet too.
The tapping was definitely coming from the engine bay, or so I believe... But as its gone all quiet, ill have to hold out until it comes back - which hopefully it wont.. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
27th Nov 2018 3:17pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Check the heat shields around the gearbox and exhaust on the passenger side. They come loose or get bent and can cause an intermittent tapping noise that can seem to be speed related.
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
27th Nov 2018 7:13pm |
His profile shows it as a Td5.... they don't have a cable (well they do, but an electric cable instead of a rotary type) |
27th Nov 2018 9:51pm |
Thanks chap, ill get me head under and start wiggling things.. Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
28th Nov 2018 10:05am |
