Home > Td5 > A tapping sound.
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
A tapping sound.
Good day all.
So before I trouble my mechanic, let see if you lovely knowledgeable people can point me in the right direction.
So on my way home from the NEC yesterday I noted a tapping sound.
At the NEC I loaded up the truck, got the wife and in-laws seated & started up The Duchess, we started to poodle home, creeping out the car park, and roads, and as I was about to go on the roundabout before the motorway I gave it a bit of welly to get up to speed...
It might have nothing to do with it. But im sure after that, it was then that the tapping noise started seemed to start, or at least got load enough for me to notice it over all the other noise....
And another note - The tapping seemed to change pitch and speed dependant on how hard I accelerated.. I was tired after an early start, long drive & long day shopping, and a long drive home, so it could all be in my head..
This morning the tapping was still there, but not as prominent... I will have a listen on the way home too, and add any changes or worthy notes.. Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #742341 26th Nov 2018 3:49pm
Exhaust manifold gasket blowing?
Post #742344 26th Nov 2018 3:53pm
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Is it dependant on speed or by revs?
If it’s revs then its engine or exhaust related, if it’s speed related then it’s drivetrain related.
Also just check that it’s not something actually in the cab, I kept hearing a squealing but it’s passenger seat / battery latch related, and a vibration from the rear was also something in the load space. I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #742353 26th Nov 2018 4:44pm
Adam17
Thanks guys, ill double check on my way home from work, and update you..
yesterday it definitely sounded like it was in front of me, in the engine bay..
Thanks for the heads up with the speed or revs comment, that's helpful, and ill be listening out on the way home..
I have heard the tapping on other diesels before, and always wondered what makes that tapping noise... Well im about to find out lol
Thumbs Up Thanks again guys Bow down Regards
Adam
Loving The Duchess
Post #742356 26th Nov 2018 5:04pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Open the front flaps to help isolate the noise and see if the tapping gets louder...g 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #742361 26th Nov 2018 5:29pm
Adam17
Hi all,
On the way home the engine sounded much better, no tapping out of the ordinary.. I had the flaps open at times and all I could hear was general engine noise.
I'll keep you updated as the week goes on. Regards
Adam
Loving The Duchess
Post #742393 26th Nov 2018 7:58pm
Swine&Small
On mine it is Small drumming her fingers on the dash, wanting to get home for her cup of tea faster
Rolling with laughter 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #742398 26th Nov 2018 8:12pm
Adam17
Lol. Regards
Adam
Loving The Duchess
Post #742418 26th Nov 2018 8:57pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
if the tapping is speed related, is it coming from the instrument panel area? If so it may just be your speedo cable needing some lubrication or pushing home firmly. A dab of grease on the instrument end may quieten it. if you have had the binnacle off lately the cable can get pulled away from the speedo. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #742498 27th Nov 2018 1:11pm
Adam17
Thanks for the info Jeffersj. this morning it was all quiet too.
The tapping was definitely coming from the engine bay, or so I believe...
But as its gone all quiet, ill have to hold out until it comes back - which hopefully it wont.. Laughing Regards
Adam
Loving The Duchess
Post #742519 27th Nov 2018 4:17pm
bob neville
Check the heat shields around the gearbox and exhaust on the passenger side. They come loose or get bent and can cause an intermittent tapping noise that can seem to be speed related.
2013 Defender 90 CSW - sold
Post #742593 27th Nov 2018 8:13pm
jeffersj wrote:
if the tapping is speed related, is it coming from the instrument panel area? If so it may just be your speedo cable.
His profile shows it as a Td5.... they don't have a cable (well they do, but an electric cable instead of a rotary type)
Post #742649 27th Nov 2018 10:51pm
Adam17
Bob
Thanks chap, ill get me head under and start wiggling things.. Razz Regards
Adam
Loving The Duchess
Post #742728 28th Nov 2018 11:05am
