Home > Technical > Help Needed - 300tdi 110 fuel pipe route |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 359 |
No pictures at the moment, but mine runs on top of the RH chassis front to rear.
22nd Nov 2018 5:28am |
Neilios Member Since: 01 Nov 2017 Location: Co. Durham Posts: 169 |
Thanks, I have that it’s the route it takes to the return at the top I am more interested in and also clip locations and pictures are always handy. Thanks.
22nd Nov 2018 6:03am |
Sorry for not posting pictures. Bit busy.
Mine is a 2006/7 model so my routing is basically the same as the TD5. |
25th Nov 2018 11:53am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10810 |
Hi Neilios mine runs along the drivers side chassis rail, as i had a new chassis on Millie in 2015 i decided that i did not want any holes drilled in it, so this is what my indy did, i have had no problems what so ever with the way it has been fixed
This is coming down from the tank, it is not a tight fit, it is a big gap there for it come through .... Click image to enlarge then it runs over/through here ... Click image to enlarge then down on the chassis rail ..... Click image to enlarge Click image to enlarge then under the seat box area, but still on top of the rail ... Click image to enlarge then starting to make it's way into the engine bay ... Click image to enlarge this is going up from the rail to the injector pump .... Click image to enlarge i hope this helps you 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
25th Nov 2018 8:33pm |
Perfect thanks, that’s pretty much the route I decided on today when in the garage, I am looking to get some spiral rapping material for added protection.
25th Nov 2018 8:59pm |
Great as you can see in some of the pic's, my indy used some rubber piping for extra protection 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
25th Nov 2018 9:17pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1630 |
I find when I take the spiral stuff off it’s always full of muck. |
26th Nov 2018 12:12am |
