![]() | Home > Technical > Help Needed - 300tdi 110 fuel pipe route |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 364 ![]() ![]() ![]() |
No pictures at the moment, but mine runs on top of the RH chassis front to rear.
Neilios Member Since: 01 Nov 2017 Location: Co. Durham Posts: 170 ![]() ![]() ![]() |
Thanks, I have that it’s the route it takes to the return at the top I am more interested in and also clip locations and pictures are always handy. Thanks.
Sorry for not posting pictures. Bit busy.
Mine is a 2006/7 model so my routing is basically the same as the TD5. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10958 ![]() ![]() |
Hi Neilios mine runs along the drivers side chassis rail, as i had a new chassis on Millie in 2015 i decided that i did not want any holes drilled in it, so this is what my indy did, i have had no problems what so ever with the way it has been fixed
![]() This is coming down from the tank, it is not a tight fit, it is a big gap there for it come through .... ![]() Click image to enlarge then it runs over/through here ... ![]() Click image to enlarge then down on the chassis rail ..... ![]() Click image to enlarge ![]() Click image to enlarge then under the seat box area, but still on top of the rail ... ![]() Click image to enlarge then starting to make it's way into the engine bay ... ![]() Click image to enlarge this is going up from the rail to the injector pump .... ![]() Click image to enlarge i hope this helps you ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Perfect thanks, that’s pretty much the route I decided on today when in the garage, I am looking to get some spiral rapping material for added protection.
Great
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
I find when I take the spiral stuff off it’s always full of muck. |
