Home > Td5 > OBD plug?
Ianbrown00
2006 Defender 110 Td5 CSW Zambezi Silver
OBD plug?
I've just bought a 2001 TD5 Hard Top and for the life of me I cant find the OBD port?
I've normally found them placed beneath the middle seat, but not on this one, do all Defenders have the plug, I've read reports of earlier Td5 not having them and having to be wired in?
Any pointers, gratefully received.
Thanks
Ian
Post #741446 20th Nov 2018 1:42pm
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
I believe OBD2 ports were only added to 15p engines - 2003 onward. But if it did it’s hidden under the cubby I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #741450 20th Nov 2018 1:55pm
excossack
A 2001 OBD port should be under the front middle seat. Near to the passenger chair (on a RHD) vehicle. Mine is a 1999 model and its present. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #741454 20th Nov 2018 2:13pm
Ianbrown00
Thank you for the responses, I have stripped out the seat box and nothing under any of the seats or leading from the ECU under the drivers seat, there is a blanked off blue connector block?
Post #741473 20th Nov 2018 3:58pm
excossack
Have you a picture of said block?
You do have a TD5 don't you ? Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #741474 20th Nov 2018 4:03pm
miker
Under the front middle seat in my 1999 td5!
Post #741475 20th Nov 2018 4:14pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
It's not a standardised protocol. A regular OBD reader won't be able to connect, you'll need a Hawkeye or a Nanocom for a Td5.
J
Post #741476 20th Nov 2018 4:37pm
excossack
No but you should still have an OBD style socket (unless relocated to elsewhere) 1999 Defender TD5 110
Regards
John M0VAZ
Post #741477 20th Nov 2018 4:54pm
It may have been relocated for security reasons, of course.
Post #741479 20th Nov 2018 5:06pm
Ianbrown00
Definitely a Td5 Very Happy I have a Nanocom, so if I find it I will be able to read it, so going to have another good look under the seat box to make sure its not been tucked away somewhere.
I'll get a picture of the blue block connector and return.
Thanks for your help so far.
Ian
Post #741563 21st Nov 2018 10:55am
Martin
Site Admin
Look for pink, black, orange with light green and purple with brown wires Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #741565 21st Nov 2018 11:15am
PaulMc
The "blue block" is a circuit 'header' (C0294) - where common circuits are joined together -
The blue headers usually have four separate circuits -
 Paul.
Post #741575 21st Nov 2018 12:47pm
Ianbrown00
Yep circuit block, absolutely no sign of the obd port beneath the seat base or along the loom to the bulkhead!
Post #741593 21st Nov 2018 4:47pm
bankz5152
Some idiots cut them off.... Instagram @defender_ventures
Empire Tuning - Agent
Post #741609 21st Nov 2018 6:39pm
Could be worth removing the middle set/cubby box (whichever you have) and then the 4 screws that hold the cover plate down... the previous owner may have just pulled the socket back through the plate and zip tied it up out of the way above the gearbox (or onto the battery cable that's under there) to stop people* from accessing it "in the cab"
*people meaning thieving scrotes....
Post #741796 22nd Nov 2018 8:08pm
