![]() | Home > Td5 > OBD plug? |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
I believe OBD2 ports were only added to 15p engines - 2003 onward. But if it did it’s hidden under the cubby I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
A 2001 OBD port should be under the front middle seat. Near to the passenger chair (on a RHD) vehicle. Mine is a 1999 model and its present. 1999 Defender TD5 110
Ianbrown00 Member Since: 02 Nov 2011 Location: Scottish Highlands Posts: 11 ![]() ![]() |
Thank you for the responses, I have stripped out the seat box and nothing under any of the seats or leading from the ECU under the drivers seat, there is a blanked off blue connector block?
Have you a picture of said block?
You do have a TD5 don't you ? ![]() Regards John M0VAZ Econet Station 48 no clock |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1769 ![]() ![]() ![]() |
Under the front middle seat in my 1999 td5!
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 ![]() ![]() ![]() |
It's not a standardised protocol. A regular OBD reader won't be able to connect, you'll need a Hawkeye or a Nanocom for a Td5.
J |
No but you should still have an OBD style socket (unless relocated to elsewhere) 1999 Defender TD5 110
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
It may have been relocated for security reasons, of course.
Definitely a Td5
![]() I'll get a picture of the blue block connector and return. Thanks for your help so far. Ian |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
Look for pink, black, orange with light green and purple with brown wires
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 504 ![]() ![]() ![]() |
The "blue block" is a circuit 'header' (C0294) - where common circuits are joined together - ![]() Click image to enlarge The blue headers usually have four separate circuits - ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Yep circuit block, absolutely no sign of the obd port beneath the seat base or along the loom to the bulkhead!
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Some idiots cut them off.... Instagram @defender_ventures
Empire Tuning - Agent |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6127 ![]() ![]() ![]() |
Could be worth removing the middle set/cubby box (whichever you have) and then the 4 screws that hold the cover plate down... the previous owner may have just pulled the socket back through the plate and zip tied it up out of the way above the gearbox (or onto the battery cable that's under there) to stop people* from accessing it "in the cab"
*people meaning thieving scrotes.... |
