Home > Technical > Transfer box leaking. |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
Hope the picture shows properly. My transfer box is leaking from the area just above the filler hole. Think this is the end of the intermediate shaft?! Any help would be much appreciated towards a fix for this problem.
Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
16th Aug 2018 4:26pm |
solved this myself this weekend, transfer box off, shaft pushed back, o-rings replaced and sealant applied. back together and fingers crossed it won't leak again! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
19th Nov 2018 12:11pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 |
Has it stayed leak free? > 110 XS Double Cab
29th May 2019 8:59am |
It is still leak free!
Although that’s jinxed it now 😂 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
29th May 2019 3:48pm |
Did mine while I had the box out to do the clutch. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
29th May 2019 9:11pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17527 |
Those of you who have done this, can you tell me how you went about setting correct bearing preload for the intermediate gear?
30th May 2019 9:13am |
Piece of string, spring balance and some dodgy maths. There’s a Bearmach video on YouTube that demonstrates it much better than I could explain it. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
30th May 2019 10:23pm |
