Home > Maintenance & Modifications > Fitting fuel pickup pipe for webasto in fuel neck - TD5 |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1360 |
https://www.ebay.co.uk/itm/EBERSPACHER-LAN...1134055406
I have one of the pipes in the link above, has anyone else fit one of these to their defender? I am just about to do it and was hoping to splice into the fuel neck in situ but as I can't feed into the tank I can't be too accurate with where I make the cut, issue I have is the 110 is on the ramp immobilised and I have nearly a full tank of fuel, got the perfect chance to do it but would be better if tank was empty. Any advice or measurements as to where it has been tee'd in? Thanks |
14th Nov 2018 6:29am |
Ian825 Member Since: 31 Oct 2016 Location: East Yorkshire Posts: 11 |
a bit hazy, but shows how it sits in the rubber hose with the take off to three right of the filler tube
14th Nov 2018 3:28pm |
Click image to enlarge |
14th Nov 2018 3:29pm |
Fantastic hat Ian, thanks very much for the help
14th Nov 2018 4:09pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1598 |
on mine i used the fitting on top of the fuel pump .cut end off feed pipe in and seal, been good for years and it sits insides the filter side of things.
the last one i did was thru the pipe similar to the pictures . didn't run the heater if the car was less than 30% full of fuel. |
14th Nov 2018 7:46pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8018 |
Likewise, I have gone in through top of sender on mine with the dedicated webasto pickup. Works when tank is almost empty! Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
14th Nov 2018 9:45pm |
Have you used one of these then James?
https://rover.ebay.com/rover/0/0/0?mpre=ht...1620554507 |
15th Nov 2018 5:13am |
