Home > Technical > 90 Puma Hardtop Arch height Help please.
jst
I don't suppose anyone could please measure the height from the ground to the bottom of the eyebrow (above centre of wheel) at the front and rear, both sides, on a 90 Hardtop unladed on std suspension on 235.85s fitted to Boosts @ 25-30psi, parked on level ground. Sorry big ask i know.
i am after a rough figure, i know there are many possible variations, full tank full compared to nearly empty and vehicles not loaded the same but it will give me a starting point.
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #739112 6th Nov 2018 9:55pm
You can remove tyre size from the list of variables by measuring from the wheel centre. Darren
Post #739114 6th Nov 2018 10:02pm
jst
i know, but i thought people might find that harder guessing the middle of the rim esp if the logo is the wrong way up!.... i was trying the simple. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #739115 6th Nov 2018 10:04pm
Fair enough Laughing Darren
Post #739118 6th Nov 2018 10:16pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Hi JST, whilst not specifically answering your question, there are a few measurements here which may help.
https://gwynlewis4x4.co.uk/wp-content/uplo...rments.pdf 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #739143 7th Nov 2018 5:28am
jst
great link thank you.
mine are 285mm front (std 250-260) and 280 mm rear (std 300) working off Gwyns measurements.
so too high at front and too low on rear! swapping them around would help possibly not sure on front spring rates though.
Time to find some std springs. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #740058 12th Nov 2018 2:54pm
Procta
What we used to say back in the days of the 306. " that needs a 40mm drop and some cyclone alloys"
thats an old peugeot 306 joke from back in the day Very Happy
I would fit good standard springs alround or a decent quailty upgraded one if you have the budget. I am thinking on changing my terramera stuff, as i dont rate the dampers at all. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #740155 12th Nov 2018 8:43pm
jst
I will go genuine if i change them, or oem equivalent . Its running tf springs and shocks both of which are shocking..... Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #740159 12th Nov 2018 8:50pm
