![]() | Home > Td5 > TD5 Leaking coolant a lot |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 ![]() ![]() ![]() |
My tD5 leaking lots of coolant, engine temp goes up to 115C, car still can run, from top of engine can't see anything leaking, even the core plug area is dry, look from the bottom of the car, can see leaking like hell, fuel cooler is fine too, the radiator and hose all seems fine, the leak is from the rear bottom side of the engine I think, what it could be???
please help! ![]() ![]() ![]() https://youtu.be/jt9j4k6FwXQ |
It makes some steam sound after driving!
https://youtu.be/10n4cKW_8HI |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5859 ![]() ![]() |
As above check all the hoses. Get the plastic cover off the engine and have a good play with all the hoses. Check your heater matrix and supply hoses too.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
The water pump can often be tricky to see if it is leaking spend some time around that area and check the path of the drips.
Also as stated don’t drive it till you find and fix it. 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
![]() Click image to enlarge Thanks everyone, I think I found where it leak, but I dont know what it is? head gasket? need to look from under the fuel cooler, I think in the engine block itself! Please have a look of the youtube video I took! when I pour fluid from the expansion tank, water started leaking out, and the heater got no hot air the last time I drove the car. https://youtu.be/ZnQvbPVz1wE https://youtu.be/Wtl9zZRnFdw |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
When I replaced the head on my Td5, I found that when I removed the EGR cooler return pipe it had gone brittle like spaghetti. It wasn't leaking before I removed it but it definitely would have done at some point. Worth a look
![]() P.S. it's the one that runs along the lower edge of the engine cover and is clipped to it 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Check the fuel cooler round ones been none to leak
http://www.discovery2.co.uk/fuelcooler.html |
Fuel cooler is fine!
Do you mean the fuel cooler? |
No, the EGR cooler on the front of the block if yours is an EU3 spec engine
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
In HK its probably a ROW TD5 without EGR 02' 110 TD5 Double Cab Rebuild Thread
My TD5 doesn't have EGR cooler... |
One less thing to leak then
![]() Another place to look is the junction where the header tank, heater return pipe, fuel cooler take off and top hose return all meet. It's directly below the header tank ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Its the timing front cover leaking, you better check yours!
