Home > Maintenance & Modifications > Truck Cab Rear Window Channel Replacement |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2304 |
My rear window felts have seen better days. Having researched the topic it seems there are better performing alternatives to the OE felts.
I have read about the Woolies Trim seals, does anybody know which seal suits the Defender truck cab rear window? I am unable to measure due to being away from home. Is it a double seal or two single seals? I can't remember off the top of my head, seem to recall it being two separate channels/seals? https://www.woolies-trim.co.uk I am all ears if anybody has other suggestions/recommendations |
11th Nov 2018 1:20pm |
For closure on this, the following thread answered my question https://forums.lr4x4.com/topic/68899-defender-windows/
Trim: https://www.woolies-trim.co.uk/product/1649/small-window-channel Method: 1. Remove the window lock so that you can slide back and forth without hangups. 2. Using a flat head driver scrape out old felt from top and side channels - Note make sure you gently pull the felt out from under the part of the channel that is never exposed, you don't want to leave that in the way for later step. 3. Using flat head and pliers remove bits of plastic from bottom channel (not necessary if your bottom plastic runners are still in good shape) - Note make sure you gently pull the hard plastic out from under the window, don't break it off until it is clear. 4. leave your new felt/rubber channel in one long role, start at the top by slowly feeding it from the open side to the fixed side as you move the window back and forth push it along above the window until you can grab the tag end with pliers and pull to the rubber window stop. (do not glue in place). 5. then work it around in one long piece until you get to the bottom side of the sliding window 6. measure and cut the remaining length for what you will need to complete the job. 7. again work it under the slider until you can pull and run to stop. 8. I then pulled both corners out a bit and trimmed the sides where the bend forced it to bunch up so that the glass can seat properly. 9. Glue in place if you wish. I will leave unglued for a while to make sure all is well. my only concern is the lower channel where it should be able to drain rain water away. will see. |
12th Nov 2018 11:02am |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
Thanks Hank - that's now on my list
12th Nov 2018 11:35am |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3328 |
That looks decent.
Right now I'm rocking the environmental friendly moss look. |
12th Nov 2018 12:11pm |
