Home > Technical > Why is my oil filter different
mooro47
England 2003 Defender 90 Td5 XS CSW Java Black
Can anybody help? I've got a Defender 90 Td5 XS Station Wagon 2003 MY whicch I've only had it a couple of months. I changed the oil recently and have a problem with getting an oil filter that fits. The problem is that the threaded hole in the filters that I've brought (a Bearmach one from Devon 4x4 and a genuine LR one from Paddock) are too small in diameter and won't screw onto the filter mounting plate. The oil filter is mounted under the exhaust manifold and my local Land Rover Dealer also confirms that the filters supplied are correct and there is only one listing for a Td5 part number - LPX100590R. Well that don't fit on mine mate! Land Rover ownership is beginning to test my patience, Mad so if anyone knows of any mod that may have been made by the previous owner resulting in a larger filter thread can you let me know please. Or did Land Rover just chuck on any old thing thay had left as thay had forgotten to order enough of the right ones?
Post #73587 31st May 2011 12:58pm
Maverick
Scotland 1996 Defender 90 300 Tdi CSW Alpine White
Have you tried an earlier or a later type oil filter? Might be that at some point you engine may have been replaced. Best way, check your service book, should have the engine number written in it, if its different from the V5 or engine block hey presto its had a new engine. Just a thought Ben
Rebuilt 1996 black/white Defender 90 300 TDi
Post #73589 31st May 2011 1:51pm
Martin
Site Admin
Td5s all take the same filters.
It is a Censored awkward angle to get the filter fitted, might just not be lining up properly.
Have you measured the threaded holes in the new and old filters?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #73590 31st May 2011 2:21pm
mooro47
Hi all the filter that is on the car is noticeably bigger with regards to the size of the threaded hole in the top. I've had to put the old filter back on and it went on easily enough. There was no way the new one(s) were going to go on It's definitely a Td5, I replaced the rotor filter no problem and the picctures in the workshop manual look like my engine. Confused
Post #73679 31st May 2011 9:35pm
Martin
Site Admin
Hmm OK - is there a reference number on the old filter at all?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #73683 31st May 2011 9:45pm
Martin
Site Admin
Any progress with this?
FYI the Td5 full-flow filter has a 3/4" UNF 16 tpi thread.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #73988 3rd Jun 2011 11:37am
mooro47
Martin
Haven't had a chance to take the old filter off yet but its on the list for Saturday. I'll make sure I measure up the threaded hole in the filter whilst its off and make a note of the number/make this time Embarassed
Post #73992 3rd Jun 2011 12:33pm
Martin
Site Admin
Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #73999 3rd Jun 2011 1:03pm
Toplink
Me thinks someone has changed something on this one.I have had experience of quite a number of TD5's both in disco and defender never come across this problem.But some times the flow filter can be a Censored to get on. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #74272 4th Jun 2011 11:34pm
