Home > Off Topic > Solved! Garage lights wiring
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
OK I have found this site full of knowledgeable people and so i thought i would set a little challenge in case there were any sparkies out there.
I have bought a set of industrial florescent lights for a small spray booth project in my garage.
I know i should seek an electrician but i thought as they are just replacing a standard batten style strip light it would be a case of simply swapping them over.
However wired it up and nothing, it has power but no light. thinking they were knackered i popped a plug on the other one and plugged it in and nothing, now it could be that they are both knackered but even i am not that unlucky so its probably something i am doing wrong.
For reference they are Petrel series 7 luminaires and the original lights were simply wired in and out with 2.5mm cable back to the consumer unit.
Any advice greatfully received.
Thanks
Post #738737 5th Nov 2018 11:51am
dorsetsmith
back in 16th 17th days wiring using 3 phase 3 wire for single phase
RED OR BROWN - LIVE YELLOW OR BLACK - EARTH (SLEEVED GREEN/YELLOW) BLUE OR GREY - NEUTRAL (SLEEVED BLUE)
Post #738747 5th Nov 2018 12:41pm
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
those are some lights for a garage! Looking at the spec they have a carrier tray that takes the tubes. I would check that that is correctly installed and you are getting voltage to the fittings in the first instance. Are the ballasts correctly installed and the lamps/tubes working?
Post #738750 5th Nov 2018 1:02pm
Snowy90
Hi
Sorry for my ignorance may i ask what does this mean??? "back in 16th 17th days wiring using 3 phase 3 wire for single phase"
I havent opened them up, screw on end caps are proving tough to open but I guess if I have wired them up ok.
Brown to Red
Blue to Blue
Green/Yellow to yellow
Then I guess next step is to check inside!
Post #738757 5th Nov 2018 1:57pm
leeds
Well they are not cheap lights, depending on size over a grand.
Now a quick search shows 3 wires + earth on spec sheet here with 230 volts standard PLUS other voltages.
First think is to check the specification plate and see what voltage it is.
16/17th are editions for electrical regulations which sparkies adhere to.
Brendan
Post #738766 5th Nov 2018 2:20pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Well they are Petrel Series 7 hazardous area Ex d fluorescent fittings so require a 230v supply so should work as you have had them connected. Maybe tubes need replacing or possible starter inside the fittings.
Post #738767 5th Nov 2018 2:21pm
dorsetsmith
SWA wire you are showing manly used for 3 phase 3 wire 415 volt CCT , But also used single phase 240 v
and wire used
older wire---------------------------------------- newer wire
RED LIVE --------------------------------------- OR BROWN - LIVE
YELLOW EARTH (SLEEVED GREEN/YELLOW)----- OR BLACK - EARTH (SLEEVED GREEN/YELLOW)
BLUE NEUTRAL ------------------------------------ OR GREY - NEUTRAL (SLEEVED BLUE)
this is used as elect industry stranded
Post #738769 5th Nov 2018 2:24pm
Snowy90
Hmm
So end cap removed!
Spot the problem! Winner gets a smartie!
They are great lights ive been looking for ages and these come up on ebay! massively heavy but look great.
Thanks for your help on this one.
Post #738772 5th Nov 2018 2:39pm
Scoobeenut
Well yes it helps if they are plugged in 😄
Post #738778 5th Nov 2018 2:59pm
Snowy90
Danah!
Post #738779 5th Nov 2018 3:01pm
