Home > Camping, Caravanning and Holidays > Gas bottle level.
L110CDL
Gas bottle level.
Hi all
As i was watching one of the episodes of Grizzly n Bear they had a gadget that could tell you how much gas was left in the bottle, so i went on the internet to see what i could find and i found quite a few Rolling Eyes
So does anyone in the parish you such a gadget or could someone recommend one please Very Happy
Thank you. Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #738265 2nd Nov 2018 8:27pm
jst
leave it outside when there is going to be a frost or cold night and it will show you the level! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #738294 2nd Nov 2018 9:56pm
L110CDL
Thank you JST will try that Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #738301 2nd Nov 2018 10:07pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
I have a reasonably accurate fish weighing scale thing, spring scale type. Gas cylinders have the empty (tare) weight printed/stamped on them. Take away the tare weight from the current weight and that tells you how much gas you have left. http://www.yorkshireoffroadclub.net/
Post #738316 2nd Nov 2018 10:34pm
L110CDL
Thanks davew Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #738322 2nd Nov 2018 10:43pm
landy andy
Same as above. I used to weigh mine. No need now as I’ve got refillable bottles now.
Andy
Post #738335 3rd Nov 2018 4:44am
Merlin
According to the Caravan and Motorhome Club handbook a 6kg propane weighs 13kg full (Color Gas). So 13-6= 7kg empty. Sound like an Excel spread sheet coming on to me.
Isn't it strange that with the technology available, there isn't an app for gas and water weights, with the addition of a sensor or two?
Peter
Post #738401 3rd Nov 2018 2:10pm
gilarion
Forget about indicators none of them works as well as they should, instead go for twin bottles with either an automatic or a manual change over device, that way if one tank runs empty you always have a spare. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #738412 3rd Nov 2018 2:55pm
It's the sensor or two that makes it complicated as the standard bottles were never designed with them in mind. Given how many thousands that are in circulation, it's just not a problem worth solving. Darren
Post #738422 3rd Nov 2018 3:57pm
An auto changeover device is great but only as long as it gives some indication that it's made the change. Otherwise, you just end up with two empty bottles and no reserve. Darren
Post #738423 3rd Nov 2018 3:58pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Poor some hot water over the bottle, it will cool down on the level where the gas sits. Works on bigger bottles in any case.
J
Post #738440 3rd Nov 2018 5:18pm
dorsetsmith
Post #738442 3rd Nov 2018 5:24pm
davew
Peter
You're over complicating it. Every cylinder has it's empty weight stamped/printed on it. The weight/size of the cylinder is the weight of gas it will take. In your example of a 6KG cylinder just take the tare weight from the current weight and that's how much gas you have in kg. The cylinder you give as an example has a Tare weight of 7KG, if it weighs 13KG you have 6KG of gas (full) if it weighs 12KG you have 5KG of gas etc... http://www.yorkshireoffroadclub.net/
Post #738477 3rd Nov 2018 9:40pm
Toby60
United Kingdom 2002 Defender 90 Td5 HT Coniston Green
It’s worth noting that the tare (empty) weight on all Calor Gas branded cylinders is marked on an aluminium disc located under the valve and it is recorded in pounds and ounces. All other gas companies mark the tare weight in kilograms and it is usually printed on the top of the cylinder in front of the valve.
Some Calor cylinders have a float gauge fitted to the cylinder valve which gives an indication of the contents. However with the exception of the 5kg patio propane the others only show the contents from half full down to empty (6kg Lite and 13kg patio). ------------------------------------------------
2002 TD5 90 HT County
Post #738493 4th Nov 2018 6:20am
Toby60
Talking of apps on smart phones to see the contents of a gas cylinder, have a look at “Primagaz Easyblue App” on YouTube (sorry I don’t know how to insert a link).
It works by tapping the side of the cylinder with a metallic object in front of your smart phone. The sound it makes determines the contents and this can then be viewed on the smart phone. ------------------------------------------------
Post #738499 4th Nov 2018 8:46am
