Home > Maintenance & Modifications > fitting alloy wheels
Jas
Hi
When fitting alloys wheels, which bits do you apply anti-seize compound to i.e studs etc?
Thanks
Jas
Post #73805 1st Jun 2011 10:14pm
mick
The dealer put it round the hub that's all.
Post #73807 1st Jun 2011 10:18pm
mse
mating surface only not the threads Mike
Post #73809 1st Jun 2011 11:07pm
Maverick
Scotland 1996 Defender 90 300 Tdi CSW Alpine White
Not the threads? Why is that? Ben
Rebuilt 1996 black/white Defender 90 300 TDi
Post #73814 1st Jun 2011 11:55pm
Reducing what is basically friction fooks the correct torque up seen one or two very loose nut/bolts on wheels because of copper slip not nice
Post #73816 2nd Jun 2011 5:07am
Whilst there has always been controversy about whether or not the threads of the studs/nuts should be dry or lubricated, the surfaces of the nut which contact the wheel (ie the cone, the outer circuference, and the flange/washer) should be smeared with copper grease, mainly to prevent corrosion between the wheel and the nut.
Correct torques for fasteners are generally based on the assumption that the fastener is not lubricated.
Having said that, I have always applied a smear of copperslip to my wheelnuts to every vehicle I have owned, and have always torqued the nuts correctly (which generally means that they are nothing like as tight as people tighten them by hand), and have never, ever, had a wheelnut come loose. This has been on Series One, 2, 3, Defender, and Discovery 2 vehicles with alloy and steel wheels, as well as various lesser vehicles. One the whole you are less likely to have nut/stud problems if you do lubricate than if you don't.
The only narrow shave I ever had was on a Series One when I tightened both front wheels up fingertight only, lowered the jacks, and forgot to torque them down. I then drove about 5 miles with no problems at all before remembering they were fingertight only. They didn't come loose, and there was no knocking, nor any damage at all. Try that with dry nuts!
Post #73844 2nd Jun 2011 8:34am
mse
you generally dont lubricate the threads - in all the LRs i have owned i havent ever seen issues with the threads - but have the wheel to hub mating surface. Mike
Post #73883 2nd Jun 2011 4:01pm
