Home > Td5 > Roamerdrive Temp sensor thread.
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Hi,
Does anyone happen to know the thread of the temperature sensor thread in the extended transfer case sump?
I want to fit a gauge but having a little OCD I would like to fit a VDO Vision gauge which is in keeping with the original gauges.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #737591 30th Oct 2018 1:39pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
This is the one designed by and for the Roamerdrive unit. All you would need is an adapter to mate the electronic sensor into the drain hole in the sump cover for the VDO unit and wire it in if you wanted to go with a Vision series gauge.
https://www.britpart.com/all-parts/da1285/ 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #737626 30th Oct 2018 4:58pm
Martin
Site Admin
That's Will's question, what's the thread in the sump.
From the pic of the mechanical gauge kit, there's an adapter used between the sump thread and their sender.
I think you would have to ask Roamerdrive for the sump's thread spec, I've looked around and can't find it specified anywhere.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #737639 30th Oct 2018 6:23pm
4RF RDS
D’oh, over thought the answer for him Shocked
Worst case scenario is buy the gauge and sender that you want and just drill and tap another hole if it proves too hard to find an adapter. Thumbs Up
That capillary gauge for the roamerdrive is too fragile for my liking. Had virtually the smae Smiths gauge in my old BGT. They don’t like being moved once set up. Not a good idea for an off road vehicle. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #737670 30th Oct 2018 7:38pm
4RF RDS
3/8 npt is the thread.
From Ray Wood my friend and owner at Roamerdrive. Good luck Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #737737 31st Oct 2018 12:21am
derbywill
Thanks 4RF RDS, I had also sent a message via Facebook to them which came back with 3/8 NPT Thumbs Up
I do have the Roamerdrive gauge but do not like the fact when I mount the gauge in a mini Mud pod on top of the dash I will have to remove the capillary bulb from the transfer box sump and that it doesn't look like a O.E fit.
I am fitting a boost gauge, the standard Td5 clock (As I have a rev counter fitted) and then the temp gauge for the overdrive. All VDO vision gauges so quite pleased with that.
Will 2005 90 XS
1968 88” 2A 200tdi
2002 110 Hardtop
Post #737796 31st Oct 2018 12:49pm
