![]() | Home > Td5 > Roamerdrive Temp sensor thread. |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 564 ![]() ![]() ![]() |
Hi,
Does anyone happen to know the thread of the temperature sensor thread in the extended transfer case sump? I want to fit a gauge but having a little OCD I would like to fit a VDO Vision gauge which is in keeping with the original gauges. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
This is the one designed by and for the Roamerdrive unit. All you would need is an adapter to mate the electronic sensor into the drain hole in the sump cover for the VDO unit and wire it in if you wanted to go with a Vision series gauge.
https://www.britpart.com/all-parts/da1285/ 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6658 ![]() ![]() ![]() |
That's Will's question, what's the thread in the sump.
From the pic of the mechanical gauge kit, there's an adapter used between the sump thread and their sender. I think you would have to ask Roamerdrive for the sump's thread spec, I've looked around and can't find it specified anywhere. ![]() ![]() |
3/8 npt is the thread.
From Ray Wood my friend and owner at Roamerdrive. Good luck ![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Thanks 4RF RDS, I had also sent a message via Facebook to them which came back with 3/8 NPT
![]() I do have the Roamerdrive gauge but do not like the fact when I mount the gauge in a mini Mud pod on top of the dash I will have to remove the capillary bulb from the transfer box sump and that it doesn't look like a O.E fit. I am fitting a boost gauge, the standard Td5 clock (As I have a rev counter fitted) and then the temp gauge for the overdrive. All VDO vision gauges so quite pleased with that. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
