Home > Maintenance & Modifications > Wet driver side mat.
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Hi all.
I knew I had an issue with damp mats but the other day I knelt on the floor to lean across the driver seat and I got a very soggy knee!!! It seems its getting worse.
I got in touch with LRO mag who suggested stripping off the dash and pouring water/hose down the front to see where the water is coming from.. As The Duchess is my daily, I didn't fancy stripping out the dash...
Is there any problem/specific areas I can check before going to the length of stripping it to a shell? Sad
I have a 2004 110 xs TD5
 Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #737593 30th Oct 2018 1:55pm
Grenadier
Had the same problem. Mine stemmed from a small unplugged hole on the bulk head, just under the dash, towards the door side. Almost by the middle internal hinge. You have to get in and amongst the pedals and look up to see it. Blocked it up, no water. I think this was occasionally exacerbated by a small leak through the windscreen to bulkhead seal, where rain collected in the sponge, transferred to the bolts under the windscreen blocks, trickled inside and down the lower half of the a-pillar. I’ve reproofed the seal, and cleaned and treated the bolts, water transfer and condensation seems to have stopped. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #737595 30th Oct 2018 1:59pm
Adam17
Ah, Thank you very much. I think my next weekend off will be spent digging about. Thank you. Wink Regards
Adam
Loving The Duchess
Post #737597 30th Oct 2018 2:23pm
dorsetsmith
Post #737603 30th Oct 2018 3:31pm
Hal
Do the easy check first. Take the mat out, shut the door and hose around the door seal. Get in the passenger side and look for water.
I only had to replace the door seal (less than £20) to get a completely dry cabin.
This bloke from Yorkshire is brilliant BTW
Post #737606 30th Oct 2018 3:52pm
Adam17
dorsetsmith wrote:
water lngress manual see links below
https://1drv.ms/b/s!AtZSoWFHDgnGhEXR_LnW7L0tyDit
https://1drv.ms/b/s!AtZSoWFHDgnGhERwdB-0XcdTS_UI
Thank you so much!!!! Regards
Adam
Loving The Duchess
Post #737612 30th Oct 2018 4:12pm
Adam17
Ah good idea. Thank you. Regards
Adam
Loving The Duchess
Post #737613 30th Oct 2018 4:13pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
What did you re-proof the seal with?
Post #737767 31st Oct 2018 9:15am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
There is a small drain hole in the gutter just above the centre of the Passenger door which seems unnecessary as the gutter ends a few inches away so I plugged this hole with sealant to stop water dripping straight down the passenger door. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #737773 31st Oct 2018 10:17am
Adam17
Thanks for all the advice gents, that'll keep me busy over the weekend.. Regards
Adam
Loving The Duchess
Post #737779 31st Oct 2018 10:50am
Grenadier
I cleaned the window frame and fake-vent section to remove all grime, dirt, oil etc and then applied a strip of transparent anti-stone-chip protector across the full width and wrapped round each edge. Working so far and pretty much invisible against the paint, Corris Grey Thumbs Up
I got a strip from a mate, but this is the stuff.
https://www.amazon.co.uk/Scotchgard-Clear-...B004VG88MQ Monsieur Le Grenadier
Post #737790 31st Oct 2018 11:32am
kmac
Thanks Grenadier
Post #737823 31st Oct 2018 3:41pm
excossack
For me, I think the rain comes in via the bottom of the door card, leaking out and then onto the foam lining of the mat and then wicking across the mat. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #737825 31st Oct 2018 3:43pm
Adam17
I have also found that the water is up behind the pedals in the plastic foam stuff..
Again, thanks for all the help peoples. Regards
Adam
Loving The Duchess
Post #737827 31st Oct 2018 3:47pm
landy andy
On a previous Td5 Def I had water behind pedals, was holes in bulkhead above your feet. They seal them with small circles of sticky tape. That get old and fall off.
Worth a check. Nice and easy to fix.
Andy
Post #737885 31st Oct 2018 8:39pm
