Home > In Car Electronics > waterproof 2 pin connectors - advice requested |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20342 |
What is the load / current draw? $W33T $0U7H3RN $UG4R
20th Oct 2018 10:02pm |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 326 |
It is a 180w panel so max I guess 15 amp.
20th Oct 2018 10:17pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
Anderson SB connector smallest is rated at 50 amps for 6mm2 cable
Deutsch connectors are rated at 13 amps and 0.5-1.5mm2 cable Large superseal connectors are rated at 20 amps. Now solar panel may be rated at 180 watts but what is voltage output? To charge 12 volt battery you will need a bare minimum of 12.6 volts up to 14.6 volts. Brendan |
20th Oct 2018 10:24pm |
It charges top end of 13 in the middle of summer at midday I think. That is measured off the super cheap controller that needs replacing 3
20th Oct 2018 10:30pm |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 659 |
FYI - Deutsch connectors are also available in 25A versions - DTP |
23rd Oct 2018 7:10pm |
