Home > In Car Electronics > waterproof 2 pin connectors - advice requested
Welkman
Hi all,
I need to add a waterproof connection to the roof of my 110 to allow removal and refitting of my solar panel. I have seen deutsch conectors but have no idea which size, which crimping tool etc. Anyone connected up external stuff like this before? I reckon the cables are too small for an anderson plug.
Post #735979 20th Oct 2018 9:56pm
What is the load / current draw? $W33T $0U7H3RN $UG4R
Post #735981 20th Oct 2018 10:02pm
Welkman
It is a 180w panel so max I guess 15 amp.
Post #735982 20th Oct 2018 10:17pm
leeds
Anderson SB connector smallest is rated at 50 amps for 6mm2 cable
Deutsch connectors are rated at 13 amps and 0.5-1.5mm2 cable
Large superseal connectors are rated at 20 amps.
Now solar panel may be rated at 180 watts but what is voltage output? To charge 12 volt battery you will need a bare minimum of 12.6 volts up to 14.6 volts.
Brendan
Post #735984 20th Oct 2018 10:24pm
Welkman
It charges top end of 13 in the middle of summer at midday I think. That is measured off the super cheap controller that needs replacing Smile 3
Post #735986 20th Oct 2018 10:30pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Brendan
FYI - Deutsch connectors are also available in 25A versions - DTP
Post #736402 23rd Oct 2018 7:10pm
