Home > Maintenance & Modifications > Bucket seats (Corbeau) and middle seat
EVdV
Belgium 2006 Defender 90 Td5 ST Java Black
I have my eye on a set of Corbeau seats to improve seating comfort in my 90 td5 soft top. But I need the middle seat to stay (2 kids who like to come with me).
Can anyone who has the Corbeau's confirm if the middle seat fits, or give me a measurement of the available space between the seats?
Thanks
Post #735031 16th Oct 2018 12:32pm
Rad666
United Kingdom 1998 Defender 110 300 Tdi DCPU Keswick Green
Get a roof rack🤷🏻‍♂️
Post #735107 16th Oct 2018 6:17pm
EVdV
Rolling Eyes
No one with corbeau seats on here?
Post #735345 17th Oct 2018 5:05pm
AMBxx
Sorry, I thought someone would have more experience than me.
I recently fitted Corbeau high sided seats to my 2015 Puma. The fitting plates move the seats in by over an inch. I've had to remove the storage nets that were on the side of the cubby to get them in. The passenger seat is on mud rails. These make the fit so tight that I've had to fit an extender to the seat belt stalk.
I could measure the gap later today, but I doubt very much you'll fit a middle seat in. There's only just enough room for a cubby box.
They're very comfortable though.
Post #735454 18th Oct 2018 6:05am
bankz5152
340mm from above the cubby (padded lid) inside to inside
320mm from leg bolster to leg bolster above the cup holder
50mm from the inside of the cubby to the corbeau - beind the seatbelt Instagram @defender_ventures
Empire Tuning - Agent
Post #735458 18th Oct 2018 6:54am
EVdV
Thanks for the feedback. Is the inch to the middle necessary for the back (side 'bulge') to clear the b-pillar? Maybe I can keep the original position and gain some space.
Post #735460 18th Oct 2018 7:00am
simon67
England 2004 Defender 90 Td5 HT Rutland Red
I went to Urban Truck in the UK and wanted Recaros plus the middle seat, neither the Recaros or the Corbeaus would fit with the middle seat in situ
I went with heated XS seats in the end to keep the three seat configuration
Sorry not good news
Post #735468 18th Oct 2018 7:30am
AMBxx
Needed for the B-pillar and the seat belt. Not sure you'd be able to shut the door either!
Post #735472 18th Oct 2018 7:36am
bankz5152
The corbeau subframe move the seat away from the door to clear the b pillar. I suspect the middle seat will fit. If you post the dimensions ill see Instagram @defender_ventures
Post #735489 18th Oct 2018 8:37am
EVdV
The middle seat base is 355mm, the back is 365mm.
Maybe I can space the seats a bit more outside because it's a soft top with a seatbelt bar (seatbelts not mounted to the b-pillar), but it's still too little space like bankz measured.
Xs seats might be the only solution like Simon said, or Exmoor trim's premium seats maybe.
Post #735557 18th Oct 2018 4:57pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Sorry just seen this. I had to remove mine. The wings make the seats have to go further I to the middle and don't leave enough room.
On a plus side you arm is further away from the drivers window 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #735577 18th Oct 2018 6:15pm
EVdV
I've been searching further and it looks like I will have to fabricate something anyway if I want to make any sports seat fit. Postive news is that I have 2 extra inches to the outside thanks to the soft top (no real b pillar)
There is no one who has them on stock nearby so I need a few measurements if someone has the time.
the total width of the seat base
width of the back bolsters
the height of the back where the seat widens for the bolsters.
Would be great if someone could measure it. Thanks
Post #736613 25th Oct 2018 7:23am
