Home > Technical > Td5 brake light bulb
Djcla
Any clues as to what I need to search for ie bulb type for the brake light bulb?
Post #734881 15th Oct 2018 6:39pm
Dieseljock
Scotland 2003 Defender 90 Td5 HT Zambezi Silver
R380 bulb. Twin filament stop and tail
Post #734940 15th Oct 2018 9:30pm
Djcla
Bulb swapped bu t it only works for main lights and not when I hit the brake. Is there only one way round to fit the bulbs? Not sure what's going on maybe electrical issue.
Post #735714 19th Oct 2018 3:06pm
Procta
check the contacts on the holder for corrosion, its happened to me with the indicators. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #735723 19th Oct 2018 3:49pm
rallysteve
Check the 3way connector at the back of the light. It should have three pins, i have seen several before which have lost a pin which is stuck in the plug.
Post #735724 19th Oct 2018 3:54pm
Djcla
Cheers any good way to clean the contacts?
Post #735738 19th Oct 2018 4:51pm
