Home > Technical > Td5 brake light bulb |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Any clues as to what I need to search for ie bulb type for the brake light bulb?
15th Oct 2018 6:39pm |
Dieseljock Member Since: 03 Jun 2017 Location: Inverclyde Posts: 32 |
R380 bulb. Twin filament stop and tail
15th Oct 2018 9:30pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5222 |
check the contacts on the holder for corrosion, its happened to me with the indicators. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
19th Oct 2018 3:49pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Check the 3way connector at the back of the light. It should have three pins, i have seen several before which have lost a pin which is stuck in the plug.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
19th Oct 2018 3:54pm |
Cheers any good way to clean the contacts?
19th Oct 2018 4:51pm |
