Home > Wheels & Tyres > 235 or 265? |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7906 |
235 will give slightly better turning circle and I guess marginally better mpg. I went with 265, purely looks really, maybe better high speed cornering? James
13th Oct 2018 7:06pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3676 |
Thanks James.
13th Oct 2018 7:08pm |
265's will have an impact on turning circle - you may have to adjust the lock stops to prevent rubbing. I doubt you'll be able to tell the difference in terms of handling and fuel economy, though. Darren
Thanks all. Would 265โs be 265 75 16?
13th Oct 2018 7:16pm |
Yes, that's right. Darren
13th Oct 2018 7:18pm |
265x75R16 or 235x85R16 have pretty much same standard rolling circumference. James
justinp Member Since: 24 Jun 2016 Location: Cambridge Posts: 167 |
Surprisingly my mpg improved slightly when I went from 6 year OE continental 235/85r16 to brand new BFG 265/75r16.
I had to adjust my steering lock stops which I had previously adjusted to give me the best turning circle on the 235โs, but I suspect if I hadn't adjusted it before, it would probably have been fine with the 265โs. Now gone - 2012 2.2 110 DC XS |
13th Oct 2018 8:00pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Put 265s on mine when it was about 6 months old. Didn't adjust the stops and has been fine. Bfg a/t spring/summer, Bfg mud autumn/winter.
13th Oct 2018 8:30pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
You can go 255/85/R16 with out spacers and just a little steering lock stop adjustment if you wanted to.
Depends if that tyre size is available at the moment, I'm guessing maybe not or not yet? $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
13th Oct 2018 8:33pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
255/85 is only available as KM2, whereas 235/85 and 265/75 are available as KO2, KM2, and possibly KM3.
13th Oct 2018 9:44pm |
Not sure about the KO2 ATR in 255/85 but I heard the KM3 will be shortly in that size but likely not just yet. $W33T $0U7H3RN $UG4R
14th Oct 2018 12:04pm |
Thanks guys, 265โs ordered.
14th Oct 2018 12:05pm |
sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283 |
Hi All, just picking up on this thread. I have heard that 265's are too big for standard alloys on ddci 2007, is there any truth in that? just making my decision and wanted to double check as I had not heard this previously Sweatysock
------------- 110 CSW TDCI (Puma) 2007 |
15th Dec 2018 6:18pm |
WindyJ Member Since: 18 Oct 2018 Location: France Posts: 190 |
BFGoodrich quote 7โ-8.5โ for rim size with 8โ the recommended. I believed the boost alloys are 7?
15th Dec 2018 6:29pm |
